adding a search filter drop down
Thread begun 8/27/2019 11:52 am by Jamie | Last modified 8/28/2019 11:02 am by Ray Borduin | 1643 views | 5 replies |
Jamie
On the attached page, am trying to work out how to add a dropdown search filter which will then sort based on the StaffType value (which could be 0, 1 or 2)
Have got the drop down (starting at line 102), but unsure how to add the search aspect to the existing
This is an update page, and line 102 is in the middle of the update code. I'm not sure if you attached the wrong page or have the wrong line number. I'm a bit confused about what I should be looking at.
Jamie
apologies..wrong file attached. have attached the correct one now
Your select list isn't in a <form>... So first thing you would have to do is add it to the existing form or create a new one.
Are you trying to maintain other searches as well? What happens if someone already has a search in place?
You would probably want to save the value in the session, set the selection in the list based on the session and then filter with the session value to work with your existing search effectively.
Jamie
Thanks, I *think* I am almost there....its not quite working and think its to do with my drop down. Also, I cant clear the search for some reason
I'm going to have to work on this with you in a screen share. I can't spot the problem.
