modifying a search
Thread begun 8/27/2019 1:53 am by Jamie | Last modified 8/27/2019 2:45 pm by Ray Borduin | 1523 views | 4 replies |
Jamie
modifying a search
Hey Ray
How would I go about modifying the shop search on the attached so that if a specific word was searched then it would redirect to a specified page? (basically, a manufacturer name has been changed so want any search for that manufacturer name to be redirected to a page explaining the change)
Cheers
Jamie
You can put a redirect above the search code like:
if (isset($_GET["WADbSearch1"]) && strpos("companyname",strtolower($_GET["shopSearchInput"])) !== false) {
header("location: explanation_page.php");
  die();
Jamie
thanks Ray. Is the value case sensitive? If so, should it be
if (isset($_GET["WADbSearch1"]) && strpos("companyname", strtolower($_GET["shopSearchInput"])) !== false) {
I've updated your code to not be case sensitive. Replace "companyname" with the actual company name you are trying to detect and redirect in all lower case.
Jamie
perfect thanks
