multiple file upload
Thread begun 8/17/2019 6:47 pm by randyrie405335 | Last modified 11/18/2021 2:54 pm by Ray Borduin | 4366 views | 23 replies |
randyrie405335
How do I use DataBridge's file upload to upload multiple files to the server
Are you saving the files to the database somehow or just uploading them? Do you want a certain number of uploads, or as many as the user wants?
If you just name your file upload field as an array and add the multiple attribute like: <input type="file" name="multipleUploads[]" multiple /> then it will support multiple uploads.
randyrie405335
Not working
I'm inserting the form's content to a MySQL dB which is working and am trying to upload selected files to a directory on the server which is not working... here is the code I'm using on the form: <input type="file" name="multiplUploads[]"multiple id-"upload"/> and how do I "name your file upload field as an array "... can you provide an example?
Please attach a copy of your page and I'll see if I can spot the problem.
randyrie405335
Nope... still not working
This post has been deleted.
Update line 29 from:
WA_DFP_UploadFiles("WA_UploadResult1", "FileUpload", "0", "", "false", $WA_UploadResult1_Params);
WA_DFP_UploadFiles("WA_UploadResult1", "multiplUploads", "0", "", "false", $WA_UploadResult1_Params);
It looks like you didn't update the code references when you updated the file name. You probably need to delete the form validation from that field, so remove this line:
$InsertQuery->bindColumn("FileUpload", "s", "".((isset($_FILES["FileUpload"]))?$_FILES["FileUpload"]["name"]:"") ."", "WA_DEFAULT");
randyrie405335
'corrected' PHP page still not working
I'm uploading the PHP file for you to scour and see what I'm messing up.
That looks like it would work. Can I get FTP access and a URL to reproduce? It may be that you are using an older version of the file: /webassist/file_manipulation/helperphp.php
It was updated to support multiple uploads after your purchase, so you may have an older version of that file. Reinstalling and uploading the latest could be a solution.
randyrie405335
Not Working
I do have the latest version of DBV2 installed. I'm attaching my FTP info in the private message below. Let me know if you have any issues getting to the server.
I updated the webassist/file_manipulation/helperphp.php to fix the issue with multiple uploads, so it should work now.
