queryobj issue with new version 2.22
Thread begun 8/12/2019 10:56 am by Jose | Last modified 8/14/2019 9:54 am by Ray Borduin | 1692 views | 5 replies |
Jose
Hi Ray, I am having difficulty inserting and updating a multi-language form that you did some time ago. everything was fine until version 2.18 but I realized that in version 2.22 it doesn't work anymore. I would like some idea to update so that it can continue to work with the latest version. That worries me because I am constantly updating my website and while I work with WebAssist when creating a query, that gives me the latest version of queryobj and that stops the operation of the files that use the technique you did to implement the multi language. I am currently using php 7.3.1 and MSQL 5.7.24 Apache 2.4.37 So what can I do to keep it up-to update without losing the job you did ?
What exactly happens that doesn't work?
I order to debug and fix this efficiently I would probably need:
1) a URL and steps to reproduce the problem.
2) a description of the problem (any errors or what happens that shouldn't or what doesn't happen that should)
3) FTP access so that once I reproduce the problem I can debug and fix any issues I find
Jose
I'm going to give you access to my website and FTP. All my file that have multi-languege are working as they are with V 2.18 so you can do an example with categories if you want . I'll let you the info below. I will attach queryojb 2.22 so you can test it . I have 2.18 in my live site because with 2.22 nothing happen. One thing I did was to rename one of the categories to name 2 for update and insert one for test and it work then I upload V2.22 and I did again but this time it doesn't work.
We had a redirect inside of the loop, so it wouldn't finish the updates before going to the next page. This was more of an issue with the code on the page than the include. The include was actually fixed in v2.22 because it shouldn't allow further updates after the page redirect.
I fixed the page by updating the loop on updatecategory.php. You will see that I moved these lines:
$UpdateGoTo = "dashboard?view=categories";
if (function_exists("rel2abs")) $UpdateGoTo = $UpdateGoTo?rel2abs($UpdateGoTo,dirname(__FILE__)):"";
$UpdateQuery->redirect($UpdateGoTo);
down below the close of the while loop.
Jose
Thank you very much for your help Ray, so one more question; do I have to do the same for inserting too ?
Jose
Yes, that work for insert too. Thanks again
