unlink error
Thread begun 8/08/2019 4:32 am by Sweens | Last modified 8/08/2019 10:15 am by Ray Borduin | 928 views | 2 replies |
Sweens
unlink error
Hi Ray
Upgrading a page that deletes an image and 2 thumbnails plus the page from mysl to mysql_i, I get the following error:
Warning: unlink(/home/domain/public_html/upimages/PageMainPics): Is a directory in /home/domain/public_html/webassist/file_manipulation/helperphp.php on line 786
Warning: unlink(/home/domain/public_html/upimages/PageMainPics/thumbs300): Is a directory in /home/domain/public_html/webassist/file_manipulation/helperphp.php on line 786
Warning: unlink(/home/domain/public_html/upimages/PageMainPics/thumbs150): Is a directory in /home/domain/public_html/webassist/file_manipulation/helperphp.php on line 786
Might this be if there is no image to delete? The record itself is deleted.
Cheers
Chris
This is a warning, not an error, so you can probably just turn off warnings on the page and ignore it.
For some reason the delete record code is running on a blank value. That makes it think you are trying to delete the directory and it gives that warning. I'd say just turn off error reporting on the page and ignore it if everything else seems to work properly.
Sweens
Thanks Ray - I've put a 'show if' region over the delete file region and it now works without error.
Cheers
Chris
