Warning: mysqli_stmt::bind_param(): Undefined fieldtype c (parameter 2) i
Thread begun 8/06/2019 3:34 pm by han hau lin | Last modified 8/07/2019 8:38 am by Ray Borduin | 2274 views | 1 replies |
han hau lin
Hi getting this error after inserting a basic login behavior. the rest of the page is pretty much empty.
plugin version 108, extension manager crashes so cant reinstall.
DW 19.2 | PHP 7.3.7 | MySQL
Warning: mysqli_stmt::bind_param(): Undefined fieldtype c (parameter 2) in /Library/WebServer/Documents/leftovers.net.au/webassist/mysqli/authentication.php on line 237
Fatal error: Uncaught Error: Call to a member function fetch_array() on bool in /Library/WebServer/Documents/leftovers.net.au/webassist/mysqli/authentication.php:241 Stack trace: #0 /Library/WebServer/Documents/leftovers.net.au/login.php(24): WA_MySQLi_Auth->execute() #1 {main} thrown in /Library/WebServer/Documents/leftovers.net.au/webassist/mysqli/authentication.php on line 241
Please attach a copy of the page you are working on and I can see if I can spot the problem.
