jQuery validation
Thread begun 8/02/2019 9:30 pm by Jose | Last modified 8/06/2019 9:29 am by Ray Borduin | 2723 views | 9 replies |
Jose
jQuery validation
Hi there, I realized that jQuery validation do not work after load Plugin To Div is applied. For example: I have a form with many required field, if I click submit with empty fields it is required to fill it out but if I select country to load state and I click submit then it allow me to send it empty...
Why could this be happening ?
Can I get a URL to reproduce this issue? I'm thinking there might be a javascript error on the page during the plugin load and that is causing the jquery javascript to not run properly.
Jose
Here you are;
http://360.us.tempcloudsite.com/address.php
then I'm going to record an small video so you can see better this example.
Please post FTP access. I see there are some javascript errors on the page. I'll correct them and see if that fixes the problem.
Jose
try this ftp any other thing let me know please.
What is the FTP username?
Jose
This is the username
Username: solo_360.us.tempcloudsite.com
I tested already in Dreamweaver
I updated the file:
/webassist/progress_bar/jquery-blockui-formprocessing.js
that seems to fix the problem. The issue was with using the load plugin from form on a page with a progress bar. I fixed the issue in the progress bar code in the file mentioned above.
Jose
Perfect, One more question; if I create a progress bar that reload jquery-blockui-formprocessing.js again in this case will I loose what you fixed or that it updated in webAssist too?
Yes. Back up that file. I'll be updating the extension to include this update in the next couple of days, but you would have to reinstall to prevent it from overwriting.
