From the Detail's page, I want to click on a link and a PDF invoice to be generated with the values from the details Rs
Thread begun 7/29/2019 6:24 pm by Gizza372666 | Last modified 7/30/2019 10:45 pm by Ray Borduin | 703 views | 1 replies |
Gizza372666
I have created a table called 'Payments' then I created the following pages by using data assist:
insert
update
search
detail
result
From the Detail's page, I want to add a link and when I click on this link a PDF template to be used which will contain the values from the details' Record set.
Can you please let me know how to achieve this?
or if you have a tutorial?
You are probably going to need to use a library that would add pdf editing capabilities.
Just do a google search for "edit pdf from php page" and you will find a few options out there. Once you can add content to a pdf file in general, adding it from your details page should be no problem.
