Data Bridge - No Table Found When Trying To Create Recordset but connection seems OK
Thread begun 7/24/2019 7:27 am by illbe322016 | Last modified 8/05/2019 6:10 pm by Ray Borduin | 2016 views | 6 replies |
illbe322016
I have a connection successfully set up and tested in both the testing and the remote server definitions, both successfully connect to the server. I have a page that uses the connection, recordset and queries to function properly, the page works properly on the live server. When I create a new PHP page the connection shows in the database panel with the proper fields listed, when I try to add a recordset and get a "no table found" in the dialog, when I switch to advanced mode and click on the table list I get "Error Calling Get Tables: an unidentified error has occurred". I have seen the posts about issues with the testing server definition but that connects properly to the server. Thank you for the help. Tom
Can you send me an export of your Dreamweaver Site Definition .ste file? I can use that to try to reproduce the problem and figure out what the cause is. I can't tell from your description alone, so I'd have to debug this one.
illbe322016
Site Definition
Replying to your request for my .ste.
You didn't include your username and password information in your site definition you sent, so I can't actually test it. I'd need a working connection with the ftp username and password to fully debug.
illbe322016
Sorry, my mistake
Here you go Ray
I'm not having any issues creating new recordsets on new pages using the attached site definition. Please reinstall the latest version of the extension to make sure your files are not out of date. If you continue to have problems I'll need to do screen sharing with you to fully debug this problem, since I can't reproduce it on my end.
illbe322016
Issue fixed
Hi Ray, I re-installed the extension for data bridge and it seems to have solved the issue.
Thank you as always!
Tom
