Univeral Mail .... or maybe DataBride v2?
Thread begun 7/22/2019 5:46 am by Zapman | Last modified 7/26/2019 9:51 am by Ray Borduin | 2400 views | 6 replies |
Zapman
I am using DataBridge 2 and have a simple web page that is divided into sections using id="XXXXX" format.
The page menu simply moves to and reveals each id section over a static background image.
I have added a contact form using Universal Mail (as I have done many times before) and it sends the message just fine It then attempts to redirect to the given address but fails to load the page, leaving a white screen.
If I open a new window and enter the url there, the page loads just fine, so I do not think that is the problem. I think it may be something to do with the sending session not closing as the address bar continues to display the sending address above the white screen.
So should be : index.php >> index.php#contact (complete and send form then redirect to) index.php#thanks.
But is actually: index.php >> index.php#contact (complete and send form then blank screen with address bar) index.php#contact
One further point, the blank page cannot be refreshed to display the url in the address bar, it has be done in a new window - hence my thought that this is session related?
Any thoughts please?
My thought is that doesn't make sense.... there must be something else. Can I get a url to reproduce and ftp access? It is either failing to redirect in the first place, or the url is different.
Try adding this to the top of both pages:
ini_set("display_errors",1);
A blank page usually means there was an error, but displaying errors is turned off. By turning them on it should give you something to go on. That would be my first step if I had FTP access and a URL to reproduce. Once you get the true error it would probably be a simple fix. My guess is blank space or code before the redirect on the first page causing the redirect to fail.
Zapman
Thanks for looking into this Ray.
Turning on error reporting reveals
' Fatal error: Call to a member function Prepare() on null in /home/sites/XXXXXXXX.co.uk/public_html/webassist/mysqli/queryobj.php on line 476 '
This suggested to me that there was an issue with email logging and when looking into the database I found an empty table (set to latin_swedish_ci collation!).
Deleting this table did not change the error status and the table was not recreated hence my feeling that things must be locking up here and not allowing the page to load.
I have only run the Universal Email routine an have made no other edits.
Many thanks in advance.
The FTP information isn't working for me. Please check for typos and make sure it works for you. It may be an IP address restriction keeping me out as well.
Zapman
Arrrggh! Sorry Ray - I forgot IP locking.
All should now be available to you.
The issue was that you have email logging in the database turned on, but you haven't created the log table to support it. I put the full error on the page so you can see it:
Table 'cl59-maillog.email_log' doesn't exist
You can either create that table with the necessary columns, or you can remove the email logging to eliminate the error.
Zapman
Thank you Ray.
My head is unblocked and all is now good.
