Problem with Insert sb
Thread begun 7/16/2019 12:22 pm by jlowery | Last modified 7/17/2019 5:52 am by jlowery | 911 views | 2 replies |
jlowery
On my Courses_Insert page, I'm getting the following errors when it tries to load:
Notice: Undefined index: WADA_Insert_courses in /webinfo/vhosts/manoa.hawaii.edu/docroot/ctahr/tpss/admin/courses_Insert.php on line 128
Fatal error: Uncaught Error: Call to undefined function mysql_select_db() in /webinfo/vhosts/manoa.hawaii.edu/docroot/ctahr/tpss/admin/courses_Insert.php:132 Stack trace: #0 {main} thrown in /webinfo/vhosts/manoa.hawaii.edu/docroot/ctahr/tpss/admin/courses_Insert.php on line 132
I've opened the Insert Record server behavior, gone through all the steps and then closed it again to update, if necessary. Same issue.
As a reminder, this page uses a relational table to assign one or more faculty members to the course. That could be the issue. Page attached.
Thanks - Joe
For simplicity you can use a multiple insert instead of manage relational table on the insert page. Manage relational table is only necessary on update pages.
Since you have already set it up, you can probably fix this issue by updating from:
$WA_masterKeyValue = "".$_SESSION['WADA_Insert_courses'] ."";
$WA_masterKeyValue = "".(isset($_SESSION['WADA_Insert_courses'])?$_SESSION['WADA_Insert_courses']:"0") ."";
jlowery
Thanks Ray - that did clear that first error message, but I still have the 2nd:
Fatal error: Uncaught Error: Call to undefined function mysql_select_db() in /webinfo/vhosts/manoa.hawaii.edu/docroot/ctahr/tpss/admin/courses_Insert.php:131 Stack trace: #0 {main} thrown in /webinfo/vhosts/manoa.hawaii.edu/docroot/ctahr/tpss/admin/courses_Insert.php on line 131
I see a number of mysql_select_db() function calls - one on line 131 and another on 90. Did the relational table SBs not convert to MySQLi?
