debugging mysqli insert query
Thread begun 7/14/2019 11:58 pm by CraigR | Last modified 7/19/2019 5:44 am by Ray Borduin | 3303 views | 6 replies |
CraigRBeta Tester
i have a site which has been working fine until recently, but some errors are coming to light after the host updated to a newer version of mySQL
one issue I have encountered is an insert query, which populates a table if certain criteria are met, however I am unable to check the insert statement.
here is my code
if (isset($_POST["Create"]) && isset($campaignid)) {
$new_invitees = array_diff($_SESSION['memberidsinmailing'],$already_invited);
//compare the 2 arrays, and return the member id's who are in the campaign send list, but have not already received an invitation
    //the members already sent will get another email, but they will not get a new entry in the tbleventmember table
foreach ($new_invitees as $invitedmember) {
$InsertQuery = new WA_MySQLi_Query($PowerCMSConnection_i);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "tbleventmember";
$InsertQuery->bindColumn("EventID", "i", "".isset($_GET['EventID'])?$_GET['EventID']:''."", "WA_DEFAULT");
$InsertQuery->bindColumn("MemberID", "i", "".$invitedmember."", "WA_DEFAULT");
$InsertQuery->bindColumn("InviteSent", "i", "0", "WA_DEFAULT");
$InsertQuery->bindColumn("CampaignID", "s", "".$campaignid."", "WA_DEFAULT");
$InsertQuery->saveInSession("eventmember");
$InsertQuery->execute();
$InsertGoTo = "";
      if (
function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
in order to try and debug, i added some statement on $_POST["Create"]
echo $InsertQuery->debugSQL();
but the page returns an error
Fatal error: Call to a member function debugSQL() on null
if i run the debugSQL() function on a recordset from a SELECT statement with a which is also on the page, i get the expected output.
I have set $this->Debug = true; in both rsobj.php (version 2.18) and queryobj.php (version 1.5)
This means that there were no inserts performed. Most likely your logic for returning the array of new invitees is returning no results.
Try doing:
var_dump
($new_invitees);
if (
sizeof($new_invitees) > 0) {
  echo
CraigRBeta Tester
i tried simply using a variable in a block of code on a new page as follows...
<?php require_once('Connections/PowerCMSConnection_i.php'); ?>
require_once('webassist/mysqli/rsobj.php'); ?>
require_once('webassist/mysqli/queryobj.php'); ?>
if ("" == "") {
$InsertQuery->bindColumn("EventID", "i", "275", "WA_DEFAULT");
$InsertQuery->bindColumn("MemberID", "i", "101", "WA_DEFAULT");
$InsertGoTo = "";
      if (
           echo
but this gives me the following...
Fatal error: Call to undefined method WA_MySQLi_Query::debugSQL() in D:\vhosts\inchorus\_sqldump_test.php on line 23
(though the query runs ok and the table is updated)
What version of queryobj.php are you using? That feature wasn't in earlier versions, but it should work in the current one if you reinstall.
CraigRBeta Tester
Hi Ray, it’s version 1.5,is there a newer one ?
Yes, I have version 2.2... I'll attach it.
CraigRBeta Tester
PERFECT !
Thanks again.
