Upload files - image not stored in map on server
Thread begun 7/09/2019 2:56 am by info252084 | Last modified 7/15/2019 9:09 am by Ray Borduin | 2077 views | 6 replies |
info252084
i made a simple form with 1 file upload field.
the name of the image is stored in the mysql database, that is OK.
But the image itself is not stored in the map 'w-cloud' on the server. What could be the problem?
This is the code:
<?php require_once('../Connections/testconn.php'); ?>
<?php require_once("../webassist/file_manipulation/helperphp.php"); ?>
<?php require_once('../webassist/mysqli/queryobj.php'); ?>
<?php require_once('../webassist/mysqli/rsobj.php'); ?>
$Recordset1 = new WA_MySQLi_RS("Recordset1",$testconn,1);
$Recordset1->setQuery("SELECT * FROM beeldopladen");
$Recordset1->execute();
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../w-cloud/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(($_SERVER["REQUEST_METHOD"] === "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)){
WA_DFP_UploadFiles("WA_UploadResult1", "beeld", "0", "", "false", $WA_UploadResult1_Params);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form1")) {
$InsertQuery = new WA_MySQLi_Query($testconn);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "beeldopladen";
$InsertQuery->bindColumn("beeld", "s", "".($_POST['beeld']) ."", "WA_BLANK");
$InsertQuery->saveInSession("beeldopladenID");
$InsertQuery->execute();
$InsertGoTo = "succes.php";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<title>Naamloos document</title>
</head>
<body>
<form name="form1" method="post" action="">
<p>
<input name="beeld" type="file" id="beeld" onchange="" />
</p>
<p>
<input type="submit" name="submit" id="submit" value="Verzenden">
</p>
<input type="hidden" name="MM_insert" value="form1">
</form>
</body>
</html>
Your <form> tag needs enctype="multipart/form-data". That is a necessary attribute to support file upload.
info252084
Hi Ray,
I changed <form name="form1" method="post" action=""> into <form name="form1" method="post" action="" enctype="multipart/form-data">, but now the name of the image is not stored in the mysql database, and neither is the image itself.
Can you provide FTP access and a URL so I can reproduce the issue? I'll debug it and see what needs to be changed.
In the future please attach a copy of the page you are working on with your post so I can open it in dreamweaver and take a look. I can sometimes spot the problem that way. (don't copy and paste the content of the page, actually attach the page itself)
info252084
OK, here is the info you need:
FTP:
Host: 77.241.85.78
User: webspice-cmsbe@webspice-cmsbe
Ww: !!cmsTest01
MySQL:
https://phpmyadmin.combell.com
Host: ID35834_spicycms1829.db.webhosting.be
Db: ID35834_spicycms1829
User: ID35834_spicycms1829
Ww: !!cmsTest01
url: http://webspice-cmsbe.webhosting.be/databeheer/testform.php
The file upload was working when I tested it, just the file name wasn't being inserted into the database. When doing file upload, you should use the file upload bindings for "Server File Name" instead of the form binding itself. I've updated that on your page and it appears to be working correctly now.
info252084
Hi Ray,
it works. Thank you for your SUPER support.
