Is the installed_cms.txt supposed to be deleted from the server once it is installed?
I found it in my connection file and I thought I read somewhere that it should be deleted.
No, don't delete it. That file keeps track of when the installer needs to run. If you delete it, then it will think the installer didn't complete.
