Updating cart needs second submit to work
Thread begun 7/08/2019 1:15 am by info4753 | Last modified 7/12/2019 7:50 am by Ray Borduin | 1723 views | 4 replies |
info4753
I have an older shop where adding products to the cart doesn't seem to work properly and where updating and clear cart only works on the second submit. Do you have any ideas what could cause this? http://gerspach.ch/shop/artikel.php?PRODID=31
Maybe the cart update code is too low on the page? Please attach a copy of the page and I can see if I can spot the problem. I may need FTP access to fully debug if I can't spot it in the code easily.
info4753
Thanks for your reply Ray. I've attached the cart page and the product page (http://www.gerspach.ch/shop/artikel.php?PRODID=31). It looks like there is also a problem with adding products to the cart. It sometimes adds it sometimes not (session problem?). Maybe it's the same problem? Thanks for your help in advance!
It appears this issue is related to using Cookies to save the cart information. I've updated the /WA_eCart/eCart1_PHP.php file to address this issue. Please download the updated file and back it up for your records. I'll have to update the extension to include this fix.
info4753
Thanks a lot for your help Ray!
