CSS Sculptor crash extensionmanager
Thread begun 9/16/2009 6:25 am by info341087 | Last modified 9/17/2009 1:43 pm by Jimmy Wu | 3842 views | 5 replies |
info341087
When I try to install CSS Sculptor then the extensionmanager crash. I use CS4, Another extensions install normaly. I have deleted the cashe file from dreamweaver, but it does not help anything.
Jimmy Wu
Which version of the extension are you installing? Also did you have a previous version of the extension installed? If you do, try uninstalling that version before installing the latest version.
info341087
I have the latest version 3.
I have a new laptop with vista64bits and CS4 installed
I have installled succesfull 3 extensies, formvalidator, joomlatemplate kit and capthaform.
Updated the extensionmanager to the latest.
I have tryed to install only Dreamweaver cs3, The older version.
Also tried to install CSSculpter 3.00 and I get the error see atachement.
On my XP PC the install goes good.
Jimmy Wu
I'm not sure what would be causing a sharing violation error there. Are you trying to install as the "Administrator" account or just an account that has administrator rights?
info341087
I have solved this problem. The virusscanner has caused this problem. It is the virusscanner Norman. In CS3 and CS4 I can install CSScultur v3.00.
Jimmy Wu
I'm glad you were able to figure out the issue. If you have any additional issues, feel free to make a new thread.
