Sculptor 2 in Sculptor 3
Thread begun 9/15/2009 4:51 pm by Brad Lawryk | Last modified 9/15/2009 5:23 pm by Jimmy Wu | 2128 views | 2 replies |
Brad Lawryk
Will you be able to use/edit presets you made in Sculptor 2 with Sculptor 3? If so, what would be the procedure?
Seems to me if you uninstal Sculptor 2, you would lose any custom presets you made?
Justin Nemeth
Any custom presets you created will remain in the Dreamweaver config folder and the first time you launch Sculptor 3 it will convert them to work correctly.
With that said, I would still recommend backing up your Sculptor 2 layouts using the Preset Manager just so you have a backup. You can just select all your custom presets and export them to a zip file.
Jimmy Wu
If you are removing Sculptor v2 you should export all the custom layouts that you have made and you should be able to import them after installing v3.
