Adding to cart, but not carrying recordset values in item name or description?
Thread begun 6/28/2019 10:06 am by Nathon Jones Web Design | Last modified 10/16/2019 1:41 pm by Ray Borduin | 2803 views | 7 replies |
When I click the Add to Cart button, it appears to add to cart but it's not bringing over the dynamic recordset values in the item name and dsecrption?
This is my add to cart code:
// WA eCart AddToCart
if (isset($_POST["eCartSMC_1_ATC"]) || isset($_POST["eCartSMC_1_ATC_x"])) {
$ATC_itemID = $rsEDITFORM->getColumnVal["SMCorderID"];
$ATC_AddIfIn = 4;
$ATC_RedirectAfter = "../health-screening-form-checkout.php";
$ATC_RedirectIfIn = "";
$ATC_itemName = "Sports Medical Certificate Form Ref. ". $rsEDITFORM->getColumnVal("SMCformID") ."";// column binding
$ATC_itemDescription = "Order Ref. SMC ". $rsEDITFORM->getColumnVal("SMCorderID") ."";// column binding
$ATC_itemThumbnail = "";// column binding
$ATC_itemWeight = floatval("0");// column binding
$ATC_itemQuantity = floatval("1");// column binding
$ATC_itemPrice = floatval("65");// column binding
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$eCartSMC->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice);
if ($ATC_RedirectAfter != "" && $eCartSMC->redirStr == "") {
$eCartSMC->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
I've provided a link and instructions on how to replicate this in the thread below.
Hope you can help. Thank you.
NJ
Link and details below. Thank you.
Your recordset: $rsEDITFORM wasn't returning a result after the form submit. I updated it to fix the issue.
There is a still a problem here. It's carrying over the SMCformID and SMCorderID values to the subsequent page, health-screening-form-checkout.php, but when it gets there I have a recordset on that page that's supposed to pre-fill the billing information form.
The recordset is as follows:
$rsCONFIRMORDER = new WA_MySQLi_RS("rsCONFIRMORDER",$csdbmysqli,1);
$rsCONFIRMORDER->setQuery("SELECT SMCorders.*, SMCuser.*, userORDER.SMCuserFIRST AS USERORDERfirst, userORDER.SMCuserSUR AS USERORDERsur, userORDER.SMCuserUSER AS USERORDERemail, userORDER.SMCuserADD AS USERORDERadd, userORDER.SMCuserADD1 AS USERORDERadd1, userORDER.SMCuserCITY AS USERORDERcity, userORDER.SMCuserREGION AS USERORDERregion, userORDER.SMCuserZIP AS USERORDERzip, userORDER.SMCuserPHONE AS USERORDERphone, userORDER.SMCuserMOBILE AS USERORDERmobile, SMCcountries.SMCcountryID, SMCcountries.SMCcountryCODE, SMCcountries.SMCcountryNAME, SMCform.*
FROM SMCorders
INNER JOIN SMCuser ON SMCorders.SMCorderUSERID = SMCuser.SMCuserID
INNER JOIN SMCuser userORDER ON SMCorders.SMCorderUSERID = userORDER.SMCuserID
INNER JOIN SMCcountries ON userORDER.SMCuserCOUNTRY = SMCcountries.SMCcountryID
INNER JOIN SMCform ON SMCorders.SMCorderFORMID = SMCform.SMCformID
WHERE SMCorders.SMCorderID = ?");
$rsCONFIRMORDER->bindParam("i", "".(isset($_SESSION['eCartSMC_OrderID'])?$_SESSION['eCartSMC_OrderID']:"") ."", "-1"); //WAQB_Param1
$rsCONFIRMORDER->execute();
This checkout page works for both new orders and returning orders so I need the order ID, in the above process, to also be set up as the eCartSMC_OrderID session. Is that possible?
Thank you.
NJ
This could be an issue with the Session variable not being set correctly in the first place, or an issue with the query itself not returning a result.
I'd first confirm that the Session variable is being set and is available. Then I'd use:
<?php echo($rsCONFIRMORDER->debugSQL()); ?>
And then copy/paste the result into your phpMyAdmin to see if it has a result. I'm not sure if the session variable is the issue or the Query or how you have it populated on the page. If the query returns the correct result and the session appears to be set, then then issue is with how you are using the recordset to populate the form.
This is the Add to Cart button...
<form name="eCartSMC_1_ATC_<?php echo($rsEDITFORM->getColumnVal("SMCformID")); ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".htmlentities($_SERVER["QUERY_STRING"]):""; ?>">
<input type="hidden" name="eCartSMC_1_ID_Add" value="<?php echo($rsEDITFORM->getColumnVal("SMCformID")); ?>">
<button type="submit" class="btn btn-info" name="eCartSMC_1_ATC" id="eCartSMC_1_ATC">Proceed to Payment <i class="fal fa-shopping-cart"></i></button>
</form>
I've got a hidden field called eCartSMC_1_ID_Add with the form ID value, <?php echo($rsEDITFORM->getColumnVal("SMCformID")); ?>, and this is directing to the health-screening-form-checkout.php page.
My recordset on health-screening-form.php is filtering by $_SESSION['eCartSMC_OrderID'] so perhaps that's why the value doesn't always carry over?
I'm confusing myself, as I type here.
Would a solution be to change my recordset to filter by $_SESSION['eCartSMC_OrderID'] OR $_POST['eCartSMC_OrderID']?
Is the Add to Cart behaviour event even a POST though?
Urggh. My brain is hurting.
Are you free to set up this IPN PayPal thing tomorrow, Thursday or Friday this week and perhaps we could iron out thigns like this whilst we're at it?
Cheers.
NJ
I should have time tomorrow. Send me a message via Skype to coordinate a time.
Thank you Ray.
The Add to Cart behaviour isn't posting my hidden form field value. My guess is that it's not supposed to.
I added a Set Session Value behaviour:
@session_start();
if (!isset($_SESSION["eCartSMC_OrderID"])) {
$_SESSION["eCartSMC_OrderID"] = "".($rsEDITFORM->getColumnVal("SMCorderID")) ."";
...so that the session would defintely exist, prior to clicking the Add to Cart button. Sure enough, when I display this session value on the add to cart page it exists, and it's the correct number (the order ID from my Orders table).
Clicking the Add to Cart button takes the user to the card/billing address page (health-screening-form-checkout.php) and, on that page, I have the following recordset:
FROM SMCorders
This recordset is returning a record, because I have it populating the billing address fields. However, the cart summary section at the bottom has omitted the form ID and order ID, despite them being set in the Add to Cart behaviour on the previous page (itemName and itemDescription):
$ATC_AddIfIn = 4;
$ATC_itemName = "Sports Medical Certificate Form Ref ". $rsEDITFORM->getColumnVal("SMCformID") ."";// column binding
$ATC_itemDescription = "Order Ref SMC". $rsEDITFORM->getColumnVal("SMCorderID") ."";// column binding
else {
My conclusion is that this is nothing to do with the session values, it is simply that the Add to Cart behaviour is not allowing/storing the recordset values specified in the itemName and itemDescription sections, which is why they are not displaying in the cart summary section on the subsequent page. That's an issue that I can't resolve without your help.
Will Skype message you around 5pm GMT.
Thank you.
NJ
