Sessions problems from search
Thread begun 6/25/2019 10:28 am by mrs | Last modified 6/27/2019 6:32 pm by Ray Borduin | 2868 views | 7 replies |
mrs
I'm having a couple of problems with search results and sessions. I've got a session being created that is called WASearch_WADAtbl_product and it is filtering the results as expected, but in order to clear the search results to display all products again I have created a page called search-clear.php which kills the afore mentioned session.
I've added a section on the page that should show when the session has content and hide when it's empty by way of 'WebAssist Show If'... but it's constantly showing and I don't know why!
Added to that, I have tried to show what the user has searched for, but all I am getting is 'Array'.
I seem to have a mass of search sessions available to use for some reason, but none of them are displaying anything apart from the session WASearch_WADAtbl_product, and when I kill it off, it still shows!
What have I done wrong? It's as though the behaviour of the upgraded DA has changed because it seems to be going something different to what I am used to, but I assume it's something I've done.
Files attached.
Thanks.
Update your IF statement from:
if ("".$_SESSION['WASearch_WADAtbl_product']  ."" != "") {  // WebAssist Show If
        <div class="row mbtm30 col-12">
            Search filter active: <?php echo $_SESSION['WASearch_WADAtbl_product']; ?>. <a href="search-clear.php">Remove filter</a>
        </div>
// ("".$_SESSION['WASearch_WADAtbl_product']  ."" != "")
if ("".((isset($_SESSION['WASearch_WADAtbl_product'])&&sizeof($_SESSION['WASearch_WADAtbl_product'])>0)?"1":"")  ."" != "") {  // WebAssist Show If
        </div>
// ("".((isset($_SESSION['WASearch_WADAtbl_product'])&&sizeof($_SESSION['WASearch_WADAtbl_product'])>0)?"1":"")  ."" != "")
That should fix it.
The session variable that saves the search settings is stored as an array in the latest version of the rsobj.php file. So you check for it has to make sure that it exists and that its length is not zero.
mrs
Cheers Ray, that worked.
How do I build that in the show region utility tool to work with the search results, or is it a case of just knowing that code?
Also, my understanding of an array is that it is one or more results returned and those collectively are called an array of results. So, how do I get at the contents of the array in order to show the search term entered?
Basically, I want to create a box with a bit like this below:
[ X King size bed ]
where the user can get the visual cue to click on the X to kill the search.
You would have to know that code to add a conditional region.
The values stored are based on the search inputs you are using. If you add this:
var_dump($_SESSION['WASearch_WADAtbl_product']);
and send me the result... then I can tell you how to reference a particular value based on that.
mrs
I just tried that and got NULL
So I tried dumping all sessions rather than a specific one and got:
array(3) { ["WAENCRYPTEDRETURNUSED"]=> bool(false) ["WAENCRYPTEDRETURNSUCCESS"]=> bool(false) ["WASearch_WADAtbl_product"]=> array(0) { } }
I've also tried this:
<?php print_r($_SESSION['WASearch_WADAtbl_product']) ?>
and am getting this:
Search filter active: Array ( [0] => Array ( [0] => Array ( [0] => Array ( [type] => v [comparison] => Includes [join] => AND ) [1] => Array ( [0] => fld_p_name [1] => fld_p_descrption [2] => fld_p_collection [3] => fld_p_manufacturer ) [2] => s [3] => King size bed ) ) ) .
Which I think kind of contradicts the results of the dumping of the session! The session has no value when dumped, but does when printed!
I've just noticed that I had the @ missing from the line of code <?php @session_start(); ?>. Would that have a bearing? I have just tried and it seems to have done nothing.
Then try this for writing the search value:
<?php echo(<?php
echo($_SESSION['WASearch_WADAtbl_product'][0][0][3]);
mrs
Cheers Ray, that worked a treat.
Quick question that is unrelated, but I thought I'd ask it here as it not really worth starting a new thread over; I've had a website hacked and they have placed files all over the place that are doing god only knows. I have been through and deleted many files that I know aren't mine or created by WA wizards, but I want to check that WA wizards don't create .htaccess files and especially within the WebAssist directory. I've deleted them from the live server because they didn't exist in my development server, but just wanted to make sure that I have done the right thing!
Cheers.
The first thing to do is figure out how they were able to add files. Do you have a file upload field or file manager in a place where it isn't password protected that would allow a hacker to upload files to your server?
We only have .htaccess files in the KCFinder folder and file upload folder for that tool. I think you can safely remove most, but I'm more concerned about how a hacker was able to do that and closing the security hole. If you send me FTP access to your server I can take a look and see if I can spot the security hole they might be taking advantage of.
