inline double background
Thread begun 6/24/2019 9:44 am by Jamie | Last modified 6/25/2019 11:23 am by Ray Borduin | 734 views | 2 replies |
Jamie
Hi Ray
Not sure if the solution (if there is one) is CSS, JS or PHP so am sorry if this is in the wrong category!
Have created a hero area which needs 2 background images - one that is dynamic and uploaded by the site owner and the other one an overlay (images/misc/heroOverlay.png)
I have had to set it up inline as below as not sure if there is a better way to do it using dynamic content and css? Anyway, the way I have it set I need to be able to hide the overlay image on breakpoints < 480 but as its inline I cant figure out how to do that.
<div class="coffee-span-12 heroContainer<?php if ("".($PageContents->getColumnVal("PageContentsID"))  ."" == "1") { ?> homepage<?php } ?>" style=" <?php if ("".($PageContents->getColumnVal("HeroLarge"))  ."" != "") { ?>background-image: url('plugins/./images/misc/heroOverlay.png'), url('./images/heros/<?php echo($PageContents->getColumnVal("PageImage")); ?>'); background-attachment: scroll, scroll; background-position: right center, right center; background-clip: border-box, border-box; background-origin: padding-box, padding-box; background-size: 50% 100%, cover; background-repeat: no-repeat, no-repeat;<?php } else { ?>  background-image: url('./images/heros/<?php echo($PageContents->getColumnVal("PageImage")); ?>'); background-attachment: scroll; background-position: right center; background-clip: border-box; background-origin: padding-box; background-size: cover; background-repeat: no-repeat;<?php } ?>">
which gives us an output of:
<div class="coffee-span-12 heroContainer homepage" style=" background-image: url('plugins/./images/misc/heroOverlay.png'), url('plugins/./images/heros/bg-motley-slider-content-page.jpg'); background-attachment: scroll, scroll; background-position: right center, right center; background-clip: border-box, border-box; background-origin: padding-box, padding-box; background-size: 50% 100%, cover; background-repeat: no-repeat, no-repeat;">
Jamie
I'm afraid I don't really understand the question or issue. What exactly is wrong on the page? What do you want to do differently? Maybe call me so you can explain because I don't quite understand what you are trying to do or what I should be looking at.
Jamie
sorry, am using 2 background images (1 layered over the other) in 1 container element.
The top layer will always be the image heroOverlay.png, the bottom layer will always be a dynamic image.
Because the bottom layer is dynamic, I have had to put the css code inline.
The problem that having the css inline brings is that on breakpoints below 480 I dont know how to hide the top layer without affecting the bottom layer
I've solved this 'problem' by creating a 2nd container element and layering it over the original each one with 1 background. It works...
