Single user won't stay logged in
Thread begun 6/21/2019 11:27 am by Justin@AdventDesign | Last modified 6/25/2019 4:12 pm by Ray Borduin | 1672 views | 5 replies |
Justin@AdventDesign
On an older site (probably 3 years old), the client notified me of a peculiar. We have one, and so far as we know only one, user that when the login, they are taken to the correct 'favorites' page, showing all the info one would expect. However, the moment they click away from that page, it's as if they have logged out. They cannot add to cart or checkout, as it immediately kicks them to the login page as if they are not logged in.
I have tested with other accounts with a similar access level, and they function fine. It's only this one account that seems to have the issue. I've looked at their user info in the user table, and I don't see anything out of the ordinary.
Any thoughts on things to check? I'm at a loss for how to troubleshoot.
Probably their browser settings. They probably turned off Cookies and/or Session Cookies. I'd have them try another browser or reset their browser settings to the default settings and that would likely fix the problem.
Justin@AdventDesign
I wish it was that easy. I've tried it from two different browsers on my end and get the same issue. I try a test account with the same user access level using my same browser and have no problem. PMing you the two accounts so you can see from your end.
I'll need FTP access to debug this issue. I was able to reproduce the problem, but I can't be sure of the cause without debugging the site directly.
Justin@AdventDesign
See PM
On line 159 of account/index.php you have:
<?php $_SESSION['product_case'."".$row_rs_favorite["title"] ." ".$row_rs_favorite["subtitle"] .""] = $row_rs_favorite['case'?>
This causes some session variable names to have special characters which aren't allowed. I think the specific issue is the "!" in one of them, but they also have slashes, commas, and single quotes, but I think the exclamation point is the one causing issues.
I commented out that line and the user stays logged in.
