[Data Bridge 1] Delete file not working alog Delete record
Thread begun 6/19/2019 7:37 am by SCar87011738 | Last modified 6/20/2019 9:07 am by Jose | 1685 views | 3 replies |
SCar87011738
[Data Bridge 1] Delete file not working along with Delete record
Hello all,
I have a detail page (created with "data assist pages") that displays a record.
This record contains 4 file fields.
The detail page is set to allow the user to delete the record.
The delete record server behaviour works correctly.
But since there are 4 file related to the deleted record, I need to delete them too.
So I added 4 delete file server behaviours.
But after deleting the record the files are still there.
I try to attach the detail page, in case someone can see what's wrong with it.
TIA for any help
tony
Replace this:
action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>"
with this:
action=""
It will appear two times on the page. That should fix the problem. The issue is that the form action isn't forwarding the $_GET variable you are using to filter the recordset. So after submitting the recordset isn't able to find the row with the files that need to be deleted.
By setting the action="" property, any parameters passed to the page are forwarded through the submit automatically.
SCar87011738
Hello Ray,
thanks for your reply.
I changed the form actions but nothing changes.
Please note that the code has been generated by Data Assist Pages.
I made just little adjustements to the dates display format.
Could it be the local LAMP server? (php 5.3)
Tony
SCar87011738
Hi Ray,
just to let you know that I recreated a similar page in DB2 and it works out of the box.
Tony
