Replicating store product menu on site home page
Thread begun 6/18/2019 3:34 pm by Patrice | Last modified 6/19/2019 1:57 pm by Ray Borduin | 3517 views | 9 replies |
PatriceWebAssist
I have the cart installed in its own powerstore folder. On the site home page, I have an area where I want to insert just the product menu so customers can pick out a category from that menu and go immediately to the cart for that category. If you can point me in the right direction of which elements I should do for an include, I'd appreciate it. I don't want to do just a one button tied to search all products (/products_results.php) but rather capture the menu itself.
Open up the file:
webassist/themes/[your theme]/plugins/plugins.php
Find thes lines:
} else  {
    $WASideMenu = new WA_Include('../../../plugins/side_menu/nested_accordion/sidemenu.php');
    require($WASideMenu->BaseName);
    $WASideMenu->Initialize(true);
move it out of the else statement, so the code becomes:
Now open your index page: webassist/themes/[your theme]/templates/index.dwt.php
in the header just below the <title> tag make sure this code exists:
<?php echo(isset($WASideMenu)?$WASideMenu->Head:""); ?>
Then wherever you want the menu to appear add:
<?php echo($WASideMenu->Body); ?>
PatriceWebAssist
Awesome! I will give a try! Thank you so much!
PatriceWebAssist
probably wrong guess... I'll try
no the closer is above. You removed the else { opener and the closer } below... so it should be balanced if you followed my instructions.
PatriceWebAssist
thank you... I will give it a try
PatriceWebAssist
I believe I followed the instructions but the home page (outside of the cart) is not showing the menu. Wouldn't I need some connections related to the cart to get it to show up?
PatriceWebAssist
I did a tester page, and added this, which resulted in a partial solution. It is now listing the items in the catalog, but not the colors or the click throughs, so I'm not there yet.
I added:
require_once('PowerStore/webassist/themes/theme_open.php');
$WAIncludeContent = new WA_Include(__FILE__);
$WACatalogResults = new WA_Include('PowerStore/webassist/plugins/catalog/themed/results.php');
require($WACatalogResults->BaseName);
$WACatalogResults->Initialize(true);
I'll need FTP access to debug and look at the code on the page.
PatriceWebAssist
Thanks Ray, but I don't want to pester you. I'll just mock up a red menu and link to each cat. Not that big of a deal. I just thought there might be a shortcut. Thank you though!
