Databridge2 Search a dropdown problem
Thread begun 6/16/2019 12:36 pm by john70964 | Last modified 6/18/2019 3:25 pm by Ray Borduin | 3162 views | 7 replies |
john70964
Hello Ray
I am trying to create a search > results > detail set with WA Database Data Assist Pages
In this process entering information in the fields gives a correct result except when I come to selection fields.
When a field is a selection from a drop down list the resultant search does not give the correct result.
I simplified the drop downs and created a List Values non-dynamic in this case a new or used value
and I wonder if you can please see where I am going wrong.
If New is selected I see a list including Used
Many thanks
John
Select elements work exactly like input elements. I think the issue you are having is that your select has name="0". Form elements can't have names that start with a number. Try renaming your select element and update the results page to use the new select element name when filtering the database.
john70964
Thanks Ray
I have the drop down working now but unless I select New or Used I get no results.
If I select New or Used I get a correct result.
Please see attachment
Instead of:
<option value="0">New or Used</option>
you will need:
<option value="">New or Used</option>
Right now it would literally look for the value "0" in the database. Only blank values are ignored in searches.
john70964
Thank for sorting that out for me Ray
The same list now includes different Categories and I have a Categories selection drop down.
In this Categories list I have tried to use the pointers you gave me in the "new or used" list.
But when I search just using the categories list I get all categories showing.
Can you see where I am going wrong again please?
This page looks fine... the issue might be on the results page. Can I see a copy of that as well.
john70964
Thanks Ray
Please see PM
It looks like when you changed the input to a select you also changed it from name="Category1" to name="Category".... change the name back to Category1 on the search page and that should fix the problem.
