Issue with mariaDB
Thread begun 6/12/2019 1:46 pm by Patrice | Last modified 6/12/2019 5:59 pm by Ray Borduin | 1441 views | 3 replies |
PatriceWebAssist
Issue with mariaDB
A few months ago, you helped me fix an issue with characters when my server was upgraded to MariaDB. You had me insert a line in the connections folder.
I added this line to your file /cart/Connections/PowerStoreConnection.php on line 22:
ini_set("default_charset","utf-8");
Working on a new site, and I did do that for the powerstore connection. All good.
But now I am building out the admin area for page content and all the <p> etc are showing up. I went into connections and added that line, under the set_charset but it didn't help.
$webers_i = mysqli_init();
if (defined("MYSQLI_OPT_INT_AND_FLOAT_NATIVE")) $webers_i->options(MYSQLI_OPT_INT_AND_FLOAT_NATIVE, TRUE);
$webers_i->real_connect($hostname_webers_i, $username_webers_i, $password_webers_i, $database_webers_i) or die("Connect Error: " . mysqli_connect_error());
$webers_i->set_charset('utf8');
Perhaps it doesn't go in the connections folder in this case? On the page that uses the db content?
Thanks much.
The MySQLi library includes Cross Site Scripting protection by default and prevents html and script from running on the page. To override that and allow html to render, just add a "false" argument to the getColumnVal() method like:
<?php echo($Recordset1->getColumnVal("column1",false)); ?>
PatriceWebAssist
Thank you but where does this go?
ah I think I see...
Got it! thanks!!
PatriceWebAssist
Note to self for later reference. This applies to where I have incorporated the html editor for admin. It isn't needed on a plain field, just the ck html editor boxes.
