kc finder image path
Thread begun 6/12/2019 7:57 am by Jamie | Last modified 7/11/2019 4:12 pm by Ray Borduin | 4026 views | 8 replies |
Jamie
Having a couple of problems with KC Finder.
When adding an image from it into the html editor, its using the path /home/sites/6b/5/527344ae0c/public_html/clients/domain/files/dorset.jpg rather than /domain/files/dorset.jpg
and if I change the config file to set a maximum image width of 1200 (leaving the height to 0, it uploads the image and makes it into a 1200 x 1200 image
Uploading to the latest version of KCFinder seems to have fixed this issue.
Jamie
I've found that since we did this, am not able to upload to the sub folder 'files' and it seems to be that is because the root folder is called 'files' as well.
I tried changing the root folder to 'uploads' in the kcfinder config..pho file but it seems that its not as easy as that as, although it works and can upload files etc, I get the following errors:
Notice: Undefined index: site_root in /home/sites/6b/5/527344ae0c/public_html/clients/college/webassist/framework/library.php on line 31
Notice: Undefined index: virtualdir in /home/sites/6b/5/527344ae0c/public_html/clients/college/webassist/framework/library.php on line 65
Warning: Cannot modify header information - headers already sent by (output started at /home/sites/6b/5/527344ae0c/public_html/clients/college/webassist/framework/library.php:31) in /home/sites/6b/5/527344ae0c/public_html/clients/college/webassist/kcfinder/core/class/browser.php on line 112
Warning: Cannot modify header information - headers already sent by (output started at /home/sites/6b/5/527344ae0c/public_html/clients/college/webassist/framework/library.php:31) in /home/sites/6b/5/527344ae0c/public_html/clients/college/webassist/kcfinder/core/class/browser.php on line 113
Apart from reverting the foldername to 'files' and just changing the sub folder name to something other than 'files' what would I need to do to get round the above?
Cheers
Update the framework/library.php file to the latest version and I think that will fix the issue.
Jamie
which app should I run to get the latest library.php file?
Happy 4th July btw :)_
Just add a Framework builder plugin to a blank page and it should update the file and then you can upload it.
Jamie
ok have done that and uploaded it (v 2.02?) and that hasnt made any difference
just tried adding to this folder highlighted http://prntscr.com/oanhyx but the file was added to the folder at the root named 'files'
It looks like there is a bug where the sub-folder can't be named the same thing as the root folder. This one might take me a while to debug and fix. I'm going to have to dig deep into the code. It might be easier to just avoid that naming convention for now. I'll log it as a bug I can look into when I have more time to dig around.
Jamie
Hey Ray
Not a problem and dont have an issue with the 'workaround'. Just fyi, it only seems to be on this particular installation as others have that folder structure (files/files/) and it works fine ....
