dropship drop down
Thread begun 6/11/2019 1:45 pm by Jamie | Last modified 6/13/2019 1:54 pm by Ray Borduin | 1850 views | 3 replies |
Jamie
dropship drop down
Hey Ray
Ref the drop ship aspect from yesterday, I have set up a drop down on both qthe product_insert and the inventory_update pages with 'dropship' or 'stock item'
If drop ship is selected then the ProductDropship column is updated to '1' if Stock Item is selected it is updated to 0 and an input field is shown to add the stock number.
Have attached both pages but basically just wondering a couple of things
1. how would I go about creating an update that works so that if dropship is selected it automatically updates the ProductStock column has 0 entered into it even if a value has been added to the ProductStock input field?
2. On a failed validation, if Stock Item is selected the hidden fields become hidden again..how would I go about making them remain visible if the drop down retains 'Stock Item'?
cheers
Jamie
1) Try changing line 119 from:
<input value="<?php echo((isset($_GET["invalid"])?ValidatedField("productcontentsupdate","ProductStock"):"".$WADAproducts->getColumnVal("RemainingInventory")."")); ?>" name="ProductStock" id="ProductStock" type="text" >
$stockStart
= $WADAproducts->getColumnVal('ProductDropship')?"0":$WADAproducts->getColumnVal("RemainingInventory");
if (isset(
$_GET["invalid"]) {
$stockStart = ValidatedField("productcontentsupdate","ProductStock")
<input value="<?php echo($stockStart); ?>" name="ProductStock" id="ProductStock" type="text" >
2) Update line 115 from:
<div id="StockDiv"  style="display: none;">
$showIt
= false;
if (isset(
$_GET["invalid"])) {
  if (
ValidatedField("productcontentsupdate","ProductDropship") != "1")  $showIt = true;
} else {
  if (
$WADAproducts->getColumnVal('ProductDropship') != "1") $showIt = true;
            <div id="StockDiv"  style="<?php echo($showIt?'':'display: none;'); ?>">
You should probably also update the select list selections to recognize the failed validation by updating:
<option value="" <?php if (!(strcmp("", $WADAproducts->getColumnVal('ProductDropship')))) {echo "selected=\"selected\"";} ?>>Select Type</option>
                <option value="0" <?php if (!(strcmp("0", $WADAproducts->getColumnVal('ProductDropship')))) {echo "selected=\"selected\"";} ?>>Stock Item</option>
                <option value="1" <?php if (!(strcmp("1", $WADAproducts->getColumnVal('ProductDropship')))) {echo "selected=\"selected\"";} ?>>Dropship Item</option>
<option value="" <?php if (!(strcmp("", ((isset($_GET["invalid"])?ValidatedField("productcontentsupdate","ProductDropship"):"".$WADAproducts->getColumnVal("ProductDropship").""))))) {echo "selected=\"selected\"";} ?>>Select Type</option>
                <option value="0" <?php if (!(strcmp("0", ((isset($_GET["invalid"])?ValidatedField("productcontentsupdate","ProductDropship"):"".$WADAproducts->getColumnVal("ProductDropship").""))))) {echo "selected=\"selected\"";} ?>>Stock Item</option>
                <option value="1" <?php if (!(strcmp("1", ((isset($_GET["invalid"])?ValidatedField("productcontentsupdate","ProductDropship"):"".$WADAproducts->getColumnVal("ProductDropship").""))))) {echo "selected=\"selected\"";} ?>>Dropship Item</option>
Jamie
Thanks vm Ray but its not quite working.
Have added a value (3) to the products ProductStock column and then have selected the 'dropship' option from the drop down and updated it but the ProductStock column doesnt ) and still has the value 3 in it in the db
Also, how woudl I modify for the product_insert page as I think the above was just for the inventory_update page?
cheers
We fixed this in a premier support ticket.
