Upload: rename if file exists (case sensitive)?
Thread begun 6/10/2019 8:11 am by SCar87011738 | Last modified 6/12/2019 8:48 am by Ray Borduin | 1595 views | 3 replies |
SCar87011738
Hello all,
I have a form in which the user uploads a file. The file is renamed if another file with the same name already exists.
The filename comparison is case sensitive so File1.doc is different from file1.doc. And then it gets uploaded.
But when I need to download all files to a Windows operating system pc I get lots of file overwritten, since File1.doc will overwrite file1.doc (or viceversa).
Is there a workaround for this?
TIA
tony
I have made an update to webassist/file_manipulation/helperphp.php that I have attached.
Please upload that file and then you can use:
[FileNameLower or [FileNameUpper] in place of [FileName]
That will force the file name to be all upper or all lower case when saved so you wouldn't ever have any case sensitivity conflicts.
I've also updated this file in the latest build, so if you reinstall it will be used on future applications.
SCar87011738
Hi Ray,
thanks for your reply.
Do this work also for DB1?
Thanks again.
Tony
Yes. You will just have to manually update the file to the one I attached previously.
