My hosting server updated to Apache 4 and MYSQL is 5.5. A lot of my websites with conncetion to DB are not working.
Thread begun 6/07/2019 1:39 pm by JBWebWorks | Last modified 6/10/2019 11:04 am by Ray Borduin | 2886 views | 5 replies |
JBWebWorks
I received an email from cPanel saying that I needed to upgrade MYSQL to 5.7. I am in a queue to get that upgrade but not sure if that will fix the problems.
I get these errrors which are related to eCart
Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; comfycampers_Definition has a deprecated constructor in /home/bsauter/public_html/WA_eCart/comfycampers_PHP.php on line 3
Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; comfycampers_ItemDefinition has a deprecated constructor in /home/bsauter/public_html/WA_eCart/comfycampers_PHP.php on line 279
Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; WA_eCart_Rule has a deprecated constructor in /home/bsauter/public_html/WA_eCart/WA_eCart_Definition_PHP.php on line 4
Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; WA_eCartDisplayCSSLooper has a deprecated constructor in /home/bsauter/public_html/WA_eCart/WA_eCart_Definition_PHP.php on line 1000
Fatal error: Uncaught Error: Call to undefined method comfycampers_Definition::WA_eCartDefinition() in /home/bsauter/public_html/WA_eCart/comfycampers_PHP.php:5 Stack trace: #0 /home/bsauter/public_html/WA_eCart/comfycampers_PHP.php(274): comfycampers_Definition->comfycampers_Definition('comfycampers', 0, '$', true, 2, 0, 'oz', true, 2, 1, 0) #1 /home/bsauter/public_html/products.php(7): require_once('/home/bsauter/p...') #2 {main} thrown in /home/bsauter/public_html/WA_eCart/comfycampers_PHP.php on line 5
These issues are resolved in the latest version of eCart. You would just have to update your eCart object and cart display.
If you give me FTP access I can update the page manually for you.
This won't be affected by updating your MySQL version. It has to do with your php version and php settings. They must have updated your php version as well.
JBWebWorks
I downloaded and installed ecart 6.13 and it go rid of those errors and I can view the cart, but the product page still has problems.
Part of the problem is whether I have mysqli correct or not.
FTP in private message
A lot of these are just warning messages that don't effect the functionality of the page. They are only displayed because you have this on the top of the page:
error_reporting(E_ALL);
If you removed that, then they wouldn't show.
I fixed some other issues on your pages associated with having older versions of the extension on the page. It should be working for you now.
JBWebWorks
Ray,
Hopefully you see this first thing today 6/10/2019!
I messed up by removing the error reporting and then uploading the page which rewrote all of your fixes.
Could you use the ftp again and fix the older versions on the products.php page?
I just re-uploaded the two files that were causing errors. Please download them so you don't accidentally overwrite them again.
