Contact form built with Formbuilder not displaying in browser
Thread begun 6/04/2019 3:19 pm by gail.bergan407744 | Last modified 6/05/2019 3:53 pm by Ray Borduin | 2341 views | 5 replies |
gail.bergan407744
I've built a new contact form with CSS Formbuilder and Universal Email. Using the Simple Contact form, nothing fancy, with the Captcha feature on the bottom. When I go to save the file, I'm getting an error message I've never seen before: My file isn't encoded with UTF-8 encoding, and it's telling me to change it so that the special characters can be displayed (I'm assuming it's referring to the Captcha characters?). When I upload the form, the template is there but the body is completely blank.
I have no idea how to change encoding in the source data. Can someone help? File is attached. Using Dreamweaver CS6 on Windows 10.
Second and unrelated question: if I want to change something in the form once I've closed the dialog box, how do I get back into it? Can't see what to click on to open it back up...
Gail
The utf-8 message just wants you to add the necessary meta tag to the <head> section of the page like:
You can't re-enter the wizard. If you want to make changes you can make them in Dreamweaver directly. What changes are you trying to make? If you are making major changes then you can always just delete the page and start over.
gail.bergan407744
Hi Ray,
I made the change, copying the exact string you sent me into my page, but it made no difference. See attached.
Gail
Can you post a URL so I can see the issue?
gail.bergan407744
www.bergan.com/contact.php
On line 538 you have:
<noscript>
that is causing any code below it to not show unless javascript is disabled.
