How do I capture a column that's added to Cart in an array?
Thread begun 5/31/2019 10:50 am by lr_leal239405 | Last modified 1/20/2020 10:44 am by Ray Borduin | 5239 views | 22 replies |
lr_leal239405
I a'm trying to capture what's in the cart column (I added a column (hidden value in add to cart) for 'Product Category'. I want to use those values for products added to the cart to bring up some forms (with questions) based on whether that category is in the cart. I have something like:
$eCart1_CatID = ["1", "2", "3", "4", "5", "6", "7", "8", "9", "10", "11", "12", "13", "14", "15", "16", "17", "18"];
if ((in_array("1", $eCart1_CatID ))) {
echo "#fldsetcs { display:block; }";
if ((in_array("2", $eCart1_CatID ))) {
if ((in_array("3", $eCart1_CatID ))) {
echo "#fldsetssh { display:block; }";
echo "#specsssh { display:block; }";
if ((in_array("4", $eCart1_CatID ))) {
echo "#fldsetws { display:block; }";
echo "#Specswrinklestop { display:block; }";
if ((in_array("5", $eCart1_CatID ))) {
echo "#fldsetft { display:block; }";
echo "#specstrimchopper { display:block; }";
if ((in_array("6", $eCart1_CatID ))) {
echo "#specsstandardtrim { display:block; }";
if ((in_array("7", $eCart1_CatID ))) {
if ((in_array("8", $eCart1_CatID ))) {
if ((in_array("0", $eCart1_CatID ))) {
if ((in_array("10", $eCart1_CatID ))) {
if ((in_array("11", $eCart1_CatID ))) {
if ((in_array("12", $eCart1_CatID ))) {
echo "#fldsetir { display:block; }";
echo "#specsir { display:block; }";
if ((in_array("13", $eCart1_CatID ))) {
if ((in_array("14", $eCart1_CatID ))) {
echo "#fldsetaw { display:block; }";
echo "#specsadjustapull { display:block; }";
if ((in_array("15", $eCart1_CatID ))) {
echo "#specsfoxrunnertrim { display:block; }";
if ((in_array("16", $eCart1_CatID ))) {
if ((in_array("17", $eCart1_CatID ))) {
if ((in_array("18", $eCart1_CatID ))) {
echo "#fldsetbr { display:block; }";
echo "#specsbr { display:block; }";
But I want that first line to be: $eCart1_CatID[] = $eCart1->DisplayInfo("eCartCatID");
That line only captures the first value.. I need to capture all the values of that eCart column.
How to?
Thank you.
You should be able to use an IF statement like:
if ($eCart1->ConditionalTotal("Quantity", "eCartCatID", "1")) {
  echo
The ConditionalTotal function will return the sum of the first column where the second column equals the third value. So the if statement above will be the Total Quantity where eCartCatID equals 1.
lr_leal239405
Wow! as usual - That Works ! thanks a million!!!
lr_leal239405
I'm struggling with something similar: How do I get all the items from $eCart1 where the Category equals 1 (and so on).
something like
$cartitems[] = ("SELECT * FROM $eCart1 WHERE eCartCatID = 1");
I'm trying to limit the display of all that is in the cart to only those whose category is 1.
Currently I have all cart products displaying:
echo "Products Related: ";
while (!$eCart1->EOF()) {
<ul>
<li class="itemname" class="eC_ItemName">
echo $eCart1->DisplayInfo("Name");
?></li></ul>
$eCart1->MoveNext();
$eCart1->MoveFirst();
I tried this but errors out:
$eCart2 = $eCart1->DisplayInfo("eCartCatID");
$Recordset1 = new WA_MySQLi_RS("Recordset1",$convacc_cx,1);
$Recordset1->setQuery("SELECT Product_Name, Cat_ID FROM eCart_products WHERE Cat_ID = $eCart2");
$Recordset1->execute();
//$cartitems[] = ("SELECT * FROM $eCart1 WHERE eCartCatID = 1");
<?php while (!$Recordset1->EOF()) { ?>
<ul>
echo $Recordset1->DisplayInfo("Name");
?></li></ul>
$Recordset1->MoveNext();
$Recordset1->MoveFirst();
I think you might want something like:
$shown = array();
if (!in_array($eCart1->DisplayInfo("eCartCatID"), $shown)) {
$shown[] = $eCart1->DisplayInfo("eCartCatID");
$Recordset1
$Recordset1->setQuery("SELECT Product_Name, Cat_ID FROM eCart_products WHERE Cat_ID = " . $eCart1->DisplayInfo("eCartCatID"));
while (!$Recordset1->atEnd()) { ?>
<ul>
echo $Recordset1->getColumnVal("Name");
?></li></ul>
$Recordset1
->MoveNext();
$eCart1
->MoveNext();
lr_leal239405
still trying. I'm getting wrong index (1st one in row to meet criteria) and it's displaying all still.
Can I get steps to reproduce... what page should I start at? What should I add to the cart? How can I get to the error you are seeing?
lr_leal239405
addtocart , then Checkout button. On the next page is what I'm trying to fix.
You have to add something from the first products. ( It's the 'Core Support' category). Then, something the bottom 'Brakes' (or any other that is different.. When you expand with the input checkbox, you'll see what I'm talking about.
Products Related: <- it lists all the products in the cart instead of the one(s) pertaining to the category only.
The file is now an include and it's called 'relatedproducts.php'. That's where I have the code for that.
(You'll see an error pop up also that I got after I added UPS shipping on the cart page. But that's another topic).
Notice: Undefined index: eCart1_UPS_Quote in /home/jvdydf5kad9w/public_html/WA_eCart/eCart1_PHP.php on line 87
I can't seem to figure out how to add something to the cart. Do I have to register and log in first? Please provide login information for me to use.
Then post step by step instructions. Like:
1) Go to the home page
2) Click on this link
3) Click on that button ... etc.
Your first step is:
but I don't know how to do that.
lr_leal239405
Oops, you're right. I updated the link above, which is: http://www..com/eCart/
That is the products shopping cart. Sorry. (I was missing the 'eCart/). The FTP has all those files. (starting with index.php)
