trying to edit products_results.php page
Thread begun 5/30/2019 2:12 pm by Patrice | Last modified 6/03/2019 11:54 am by Ray Borduin | 3196 views | 8 replies |
PatriceWebAssist
On another cart design and running into the simplest of issues but I can't figure it out.
The products_results.php in the cart is not spacing properly. It is a break area between sections but I can't find it yet.
PatriceWebAssist
updating with link
I think I have to start over... it's not responsive...
Please describe in more detail what you want as opposed to what the page currently has. I'm sure I'll be able to help, but I don't really understand the issue fully.
PatriceWebAssist
I am going to start over. I did something wrong evidently. It's not responsive design. Fresh start tomorrow. If you follow the link in pm you will see that I messed up something or another.
if you think it can be saved, let me know, or I will start fresh.
I just need to understand what it is exactly that you want to add or remove from the current design. Is it that it isn't responsive? You expect it to look better on small screens?
PatriceWebAssist
more than that... even on full screen I have messed it up.. See pm
There are a lot of tweaks that need to be made.
One thing is that you should be using menu_black.png instead of menu_white.png since your page background is white.
Another big issue is that you have .content set with a width on line 50 of your main.css file. You need to override this in your responsive.css file so that if the page is small it doesn't force that area to be so wide.
I'd also suggest hiding the sidebar in the responsive.css so that it doesn't show on mobile at all since they can use the top menu.
I think you can work through all of the issues on this page, but you can start over too... I guess that is up to you.
PatriceWebAssist
Thanks Ray. A fresh day and I will try to get to the bottom of it. I thank you for all the insight.
PatriceWebAssist
Update: It was the issue with beginning with FreshStart as the default. Once I switched to Default as the starting point, the responsiveness, alignment etc resolved itself.
