contact form is not sending email or redirecting to thank you page.
Thread begun 9/15/2009 1:46 pm by sandy170299 | Last modified 9/16/2009 8:40 am by Jason Byrnes | 4211 views | 4 replies |
sandy170299
Everything with the contact form was working fine, until I added a new field and applied validation to it. Now, the form submits, but does not send the email, nor does it redirect to the thank you page. That's all I've changed.
My global file is :
$WAGLOBAL_Captcha_Width = "200" ;
$WAGLOBAL_Captcha_Height = "40" ;
$WAGLOBAL_Captcha_Characters = "5" ;
$WAGLOBAL_Captcha_Font = "Fonts/monofont.TTF" ;
$WAGLOBAL_Captcha_BG = "ffffff" ;
$WAGLOBAL_Captcha_Noise = "cccccc" ;
$WAGLOBAL_Captcha_Text = "333333" ;
$WAGLOBAL_Captcha_BG_transparent = "0" ;
$WAGLOBAL_Email_Server = "" ;
$WAGLOBAL_Email_Subject = "Request for Information from Web Site" ;
$WAGLOBAL_Email_To = "sandy@websailer.com" ;
$WAGLOBAL_Email_CC = "" ;
$WAGLOBAL_Email_BCC = "" ;
I'm not sure how much of the code on my contact page you want me to post, so I will wait until I hear back from someone.
If it's not going to the thanks you, it is most likely not passing validation. To check, look for the following code:
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
and change it to:
die($WAFV_Errors)
If it is not passing validation, you will have a white screen with a comma seperated list of numbers. The numbers relate to the validations that are not p[assing.
Look at the validation code, it will look like:
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Comments"]))?$_POST["Comments"]:"") . "",true,3);
The "3" at the end of this string is the validation number, look through each of the validations to determine which is failing.
Or post the coma separated string of numbers along with you page And I'll let you which is failing.
sandy170299
When I replace the block of code with the following, the form doesn't show up on the page anymore.
die($WAFV_Errors)
PostResult($WAFV_Redirect,$WAFV_Errors,"contactus");
sandy170299
Actually, I removed that entire block of code and it appears to be submitting the form now, but I suspect something is messed up with the validations.
Sorry, slight syntax error, there should be a semi colon after the die(); statement:
die($WAFV_Errors);
PostResult($WAFV_Redirect,$WAFV_Errors,"contactus" );
