$WA_redirectURL occasionally loses value
Thread begun 9/15/2009 11:47 am by coryk246725 | Last modified 9/18/2009 3:46 pm by coryk246725 | 3362 views | 4 replies |
coryk246725
Hi guys,
Every once in a while, DataAssist loses the $WA_redirectURL value after I modify an insert record or update record server behavior. There seems to be no rhyme or reason behind it, and I know for certain that I'm not manually erasing the redirect URL.
Is this a bug, perhaps? I am using version 2.0.4. Any assistance is greatly appreciated!
Thanks,
Cory
If the page does not redirect there is likely a php error occurring that is causing the redirect to fail instead of loosing the WA_redirectURL value.
Add the following code at line 1 of your page to turn on error reporting:
error_reporting
(E_ALL);
The next time the redirect fails, it should show the php error that is occurring.
coryk246725
Re: $WA_redirectURL occasionally loses value
Jason, thanks for your prompt reply. I should probably clarify my question.
What I mean is that, oftentimes when I create or edit a DataAssist insert or update server behavior, and I edit the behavior or review the generated code in Dreamweaver, the value of the $WA_redirectURL variable is occasionally blank, even though I am certain I entered a value.
As far as I can tell, I'm not doing anything that would wipe out the value, so it seems like a bug to me.
Thanks,
Cory
after entering the redirect URL, use the enter key on the keyboard to force the entry to stick before clicking the OK button.
coryk246725
Thanks, Jason. I'll try that next time and see if that does the trick going forward.
