While Loop
Thread begun 9/15/2009 8:42 am by Daryl | Last modified 9/16/2009 2:00 pm by Jason Byrnes | 5196 views | 5 replies |
DarylBeta Tester
While Loop
I am desperately trying to create an email form that has a number of checkboxes at the top of the page that allows the user to select multiple people (one email address per check box) or a department (multiple emails per checkbox).
I can get a single email address to echo from the database into the value fields for the people, but I am having issues getting all email addresses from specific column into a checkbox value.
I have been trying to learn to use the while loop but haven't managed to get it to work successfully yet.
To start with, I do not need to have checkboxes, but I do need a way that the user can select multiple people or groups of people to send the message to - if you have any other suggestions please let me know.
The method that I am using to loop the records is as follows;
$connection
mysql_connect("localhost""username""password") or die("Error connecting to database");
mysql_select_db("db_name"$connection);
$result mysql_query("SELECT * FROM units"$connection) or die("error querying database");?>
Then this for the first checkbox;
<?php while($row_rs mysql_fetch_assoc($result)){
echo
$row_rs['chair_email'].',';}?>
Then this for the second;
echo
$row_rs['sec_email'].',';}?>
But unfortunately the second set doesn't produce any results from the recordset.
Where am I going wrong?
I'm sure there must be an easier way....
When you get to the second loop the recordset is on the last record. It needs to be reset to the first record.
mysql_data_seek
($rs0);
$row_rs mysql_fetch_assoc($rs);
while(
echo
DarylBeta Tester
Im getting there slowly!!
The first set of loops work - horray!!!
<?php do { ?>
if ($row_rs_users['lsdogs_chair']=="1")
echo
$row_rs_users['email'].";"?>
} while ($row_rs_users mysql_fetch_assoc($rs_users)); ?>
<?php mysql_data_seek($rs_users0);
$row_rs_users mysql_fetch_assoc($rs_users);
if (
$row_rs_users['lsdogs_sec']=="1"
{echo
And the begining of the second set of loops works too!!
<?php do { ?>
echo $row_rs_units['chair_email'].";";?>
} while ($row_rs_units mysql_fetch_assoc($rs_units)); ?>
But unfortunately the rest of that group of loops doesn't :0(
<?php mysql_data_seek($rs_units0);
$row_rs_units mysql_fetch_assoc($rs_units);{
echo
$row_rs_units['sec_email'].";"?>
So what am I doing wrong then.....?
This line of code does not look right:
$row_rs_units = mysql_fetch_assoc($rs_units);{
the "{" at the end should cause an error change it to:
DarylBeta Tester
the reason for the
is beacuse the next part is the
echo
followed by
and then the
while
So I assume that I would need to remove the closing one too?
I have been through the code and have removed all of the
which has not changed the output at all.
After the second set of loops, the remaining ones just show the first record only.
this code does not start a loop:
You need to add another do { command:
do {
echo
