Displaying Images
Thread begun 9/14/2009 7:19 am by sturgisk383938 | Last modified 9/14/2009 8:23 pm by sturgisk383938 | 3417 views | 5 replies |
sturgisk383938
Displaying Images
How can you display images using DataAssist ? I have the images in a folder.
I am trying to create a path in the (SQL) database to the images. I want to display the company image next to the search results. Is this the right method? If not what is?
tom92909Beta Tester
To answer your question, we need to get some background information upfront...
1. SQL table structure :
Do you have a specific field in your table that DataAssist calls that is "reserved" specifically for an image filename?
2. The actual images directory :
Will that ever change?
In order to move forward here, I'm going to assume the following..
1. Yes you have a specific field reserved for an image filename.
2. The images directory is permanent and unique.
So...
The following should come as some help...
<img  src="images/<?php echo $row_WADARecordset1['image_fieldname']; ?>" width="1024" height="768" border="0">
In the above code, I'm using a standard HTML tag for an image and then combining the static images directory along with a dynamic PHP call to the DataAssist image filename binding, then I'm identifying the width and height and no border.
The Recordset and image_fieldname should match whatever they actually are in your configuration.
sturgisk383938
Images
I the reply i received is help for but i need more information to put me in the right
direction. Her are some information, the folder name is logo. This is where I am storing my images for display. In the database, I do have a field reserved for image filename. One of my questions is for the path I put logo/image in the database. Is this a good path for the folder?
<img class="WADADetailsMainImage" src="<?php echo $row_WADAjobs["logo"]; ?>"
I last replied suggested:
<img src="images/<?php echo $row_WADARecordset1['image_filename'];?>"> width"" height="" border="".
How can turn this displaying images from a folder?
tom92909Beta Tester
My thoughts are that I wouldn't include the path in your filename.
Reserve the SQL table field only for the actual filename.
Then include the path in your <img> tag and echo the field data to display the image you need.
sturgisk383938
Images
I did apply the code from your last reply. It is still not working.
For "image_fieldname" I put logo this the name of the column in my table. This column holds the names of the filenames. I want to display. I also enter the following this also include my path the the images.
<div class="WADADetailsMainImageArea"><img src="Computer/Macintoch HD/Applications/MAMP/htdocs/promotion-employment/logo<?php echo $row_WADAjobs["logo"]; ?>" width="100" height="100" border="2" />
What am I doing wrong?
sturgisk383938
I got it to work
I got it to work thank you!!!!
