Create a Forum
Thread begun 9/14/2009 12:44 am by jegoadby285710 | Last modified 10/07/2009 9:29 am by Daryl | 4947 views | 8 replies |
jegoadby285710
Create a Forum
Id like to create a Forum like this one.
Are Webassist thinking of producing something that may be able to do this? or and suggestions would be most welcome.
And also a behaviour to create a pdf from dynamic content in a php webpage.
Justin Nemeth
Check out vbulletin or phpBB, those are some of the most common forums out there.
David CHnet.com
Some hosts have <forums> pre-installed
All the functionality of these forums is pre-installed by some hosting companies. With ours you just pop in to the Admin console, activate an option, and everything works on via the URL forums.mydomain.com.
Our hosts are based in Geneva Switzerland and charge 80 euros per year per domain (correct Sept 09) for all you could want and more. This is just one of many scripts they offer pre-installed, including chat and a basic store.
Perhaps your hosts already offer this, or perhaps you could change to one?
Otherwise, every script I need I have always found something Open Source and satisfactory. Try searching for "php open source forum".
DarylBeta Tester
Originally Said By: jegoadby285710
I would like this too as all of the other options out there are very hard to configure, and from what I can tell Site Scribe only work on your machine and not on your server to allow users to be able to create pdf style reports.
David CHnet.com
Creating PDF from PHP on the fly
This works well for me ...
www.fpdf.org/
Good luck
PaulBeta Tester
The open source options previously mentioned, require seperate login, so if one were running a registration site with protected content for example, another login would just frustrate the visitor.
I think if WA pursued a commercial forum to compliment it existing products, therw would be sufficicient interest - at the right price of course!
Maybe worth lobbying your users WA huh?
DarylBeta Tester
Originally Said By: David CHnet.com
www.fpdf.org/
Good luck
I'm aware of fpdf but have found that getting the right output is difficult when using repeat regions and formatted table cells.
I think that a WA extension that had the normal type of wizard would be far much more appealing and less time consuming.
PaulBeta Tester
Darly,
Aplologies, I failed to explain my post.
My response was with regards to the earlier post in the thread concerning forums.
Paul.
DarylBeta Tester
No apology needed Paul, I understand what your response was regarding, but my reply was in response to the item in this thread...
....confused :confused: ;)
