100% Height Sidebar Help Needed.
Thread begun 9/13/2009 12:33 pm by paul363887 | Last modified 9/14/2009 8:56 am by Justin Nemeth | 2418 views | 2 replies |
paul363887
Hi I have been having a play with CSS Sculptor 3 now and have stumbled upon a problem, how can I make a sidebar 100% height between the header and the footer and not just the height of the content or a specified height in pixels etc.
Any help would be greatly appreciated.
anonymous
I assume your talking about "faux" columns where the sidebar appears to extend the entire height... CSS Sculptor actually does create Faux columns that do this, so I am not sure what problem you are running into.
Justin Nemeth
Brian is correct, using faux columns will accomplish what you need. Check out this how to for some more info: sculptor_faux_column_ht.pdf
