Script File Upload not working
Thread begun 9/13/2009 8:10 am by dataworks388155 | Last modified 9/13/2009 2:59 pm by dataworks388155 | 2151 views | 2 replies |
dataworks388155
Hi
I tried a very simple form to upload an image, but it dosent work
Can you help me sort this out please?
here is the code
<?php require_once("WA_DigitalFilePro/HelperPHP.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "Members/".$_SESSION['MM_Username'] ."",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "120",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["submit"])){
WA_DFP_UploadFiles("WA_UploadResult1", "logo", "0", "", "true", $WA_UploadResult1_Params);
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
</head>
<body>
<form action="" method="post" enctype="application/x-www-form-urlencoded" name="form1" id="form1">
<p>logo
<input type="file" name="logo" id="logo" />
</p>
<p>
<input type="submit" name="submit" id="submit" value="Submit" />
</p>
</form>
</body>
</html>
anonymous
Do you have any error messages you can share?
Also, I noticed that you are generating the folder name dynamically... which is ok but are you sure that the folder in that name exists AND does the folder have the correct permissions (777 or 755 depending on server policy)?
Best regards,
Brian
dataworks388155
That was it.
That was the problem. Changed permissions for the folder to allow read and write to it, and it is uploading now. Thanks
