php errors on page/ layout is weird/ no email from form
Thread begun 9/12/2009 6:13 am by chris384639 | Last modified 9/15/2009 3:25 pm by Jason Byrnes | 9108 views | 12 replies |
chris384639
So I have 3 issues with my page. Hopefully I can post all three here. index3.php
1. I'm getting this error:
  Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /var/www/vhosts/prodentite.com/httpdocs/contact/index3.php:5) in /var/www/vhosts/prodentite.com/httpdocs/WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php on line 3
2. My form is making my page look weird. (Is that too much technical jargon :D)
3. I am using Universal Email to send the form data to my email. Why can't I receive it?
Thanks!!!!
chris384639
Ok... I'm getting an email now from the form but it has no info in it...
Are you still have the first two problems?
if yes:
1) the error message is being caused by the blank space at the end of line 4:
trim the blank space at the end of that line:
2) Please send a link so I can investigate the css.
3) Please send a copy of the WA_Universal_Email/WAUE_index3_1.php so I can look into how universal Email is configured.
chris384639
Hi Jason-
I changed line 4... still have same problem.
Another issue- when I open the CSS Form Builder Edit Contents tab, I get these errors (please attached jpgs)
change line 5 and 6:
<?php virtual("/WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php virtual("/WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
<?php require_once("../WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("../WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
Dreamweaver will use the virtual function if the "Create Links Relative TO:" option is set to "Site" on the Local Info tab of your site definition. Change it to "Document" So that Dreamweaver will use the require_once() function instead.
In the Universal Email server behavior, you have not used any of the Dynamic data bindings to output the form in the email.
Double click the Universal Email server behavior. On the body tab, click the DW Edit icon.
Open the bindings panel, and expand the form collection. Drag the Form element bindings where the information should be displayed.
For the form builder errors, try deleting the Dreamweaver cache file from the users configuration folder, more information can be found here:
chris384639
1. Ok... I'm not following you here. Where do I find the Universal Email server behavior tab? Do I go to INSERT>WEBASSIST>UNIVERSAL EMAIL?
2. Lost me here too. I see the Bindings panel, but don't see any FORM ELEMENTS option
1) To open the server behaviors, go to Window -> Server behaviors. You can double click on the Universal Email server behavior in the list.
2) What do you see in the bindings list. can you send a screen shot.
chris384639
Opened DW and got these two errors:
There was a brief problem with our activation server, it should be fixed now. Try rebooting you computer and re activating.
chris384639
See screen shots:
