CSS Sculptor 3.0
Thread begun 9/11/2009 5:04 pm by atsuko313110 | Last modified 9/12/2009 9:10 am by atsuko313110 | 3895 views | 5 replies |
atsuko313110
CSS Sculptor 3.0
Just downloaded and installed the new version by deleting the old version but now I geta different error: onload wacs_quickinsert.htm javascript error.
I thought by deleting the WACSS.Bundle.bundle would solve the problem like before but it's a no go. After deleting the file, now I get a error message: While executing onload in wacs_quickinsert.htm, the following Javascript errors occured.
At line 145 Applications, Adobe Dreamweaver CS3; Configuration; Commands; wacs_quickinsert.js
Reference error: has autosave is not defined.
Dani Chankhour
I would recommend deleting your configuration folder and reinstalling the extension.
Please read this post for more information on how to delete your configuration folder.
showpost.php?p=15525&postcount=2
After your folder is deleted launch the extension manager and remove all extensions and then install Sculptor 3.0 by its self.
atsuko313110
CSS Sculptor 3.0 Problem
What? Delete all the configuration folder? Webassist isn't the only extension I have for Dreamweaver.
2.0.5 works ok after deleting a file in the configuration folder, now just to update to the new 3.0 I've got to reinstall all of my extension for this one extension?
Come on, there's got to be a better way then this. I'm pretty much dissappointed with you folks.
CraigRBeta Tester
try deleting the cache file within the configuration folder first, if you haven't already done it.
The cache file seems to get corrupted quite easily after installing a new extension.
reg.phipps388482
I too had the issue so I deleted the cache file MacFileCache-....dat file and this resolved the problem.
atsuko313110
Now that's what I'm talking about. Thank you very much to both. Deleting the MacFileCache did the trick.
Happy camper here.
