Error Generation Menu MM.WA Creat Processingobject is not a function??????
Thread begun 9/11/2009 1:40 pm by aduntil381143 | Last modified 9/18/2009 4:20 pm by Jimmy Wu | 4447 views | 7 replies |
aduntil381143
Am getting an error "Error Generation Menu MM.WA Creat Processingobject is not a function" when trying to create a new menu using MenuWriter.Can you please help me on this issue?
Dani Chankhour
Please trying uninstalling and reinstalling the extension, and make sure to have Menu Writer version 2.0.2.
daniel387105
I have the same problum i have email support and all they say is to write it up here i also talk so someone on live help who was no help
aduntil381143
I tried uninstalling the extension and re-installing it.Still its not working.Kindly help me out with a different solution.
Rich Petersen
Delete your cache file with Dreamweaver shut down, and then restart Dreamweaver.
C:\Documents and Settings\<username>\Application Data\Adobe\Dreamweaver CS4\en_US\Configuration
It will be something like winfilecache_84928428934.dat or something like that.
aduntil381143
It's working fine now.Thanks a lot!!
adicarlo384434
Same problem but with Vista Ultimate
Originally Said By: Rich Petersen
This does not exit in Vista...what can I do?
Thanks,
Am
Jimmy Wu
Here Are the paths for all the current main stream operating systems:
WinXP
-DW8
--C:\Documents and Settings\<Your User Name>\Application Data\Macromedia\Dreamweaver 8\Configuration
-DWCS3
--C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver 9\Configuration
-DWCS4
--C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver CS4\en_US\Configuration
Win Vista
-DW8
--C:\Users\<Your User Name>\AppData\Roaming\Macromedia\Dreamweaver 8\Configuration
-DWCS3
--C:Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver 9\Configuration
-DWCS4
--C:\Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver CS4\en_US\Configuration
Mac OSX;
-DW8
--Hard disk: Users: <Your User Name>: Library: Application Support: Macromedia: Dreamweaver 8:Configuration
-DWCS3
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver 9: Configuration
-DWCS4
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver CS4: en_US: Configuration
(Please note that <Your User Name> Should be replaced with the User name you use to log into your computer)
NOTE:
On Windows Computers, The AppData or Application Data folders may be set to be hidden.
To View Hidden Folders in Windows Vista:
1) In The Windows Explorer, Click the "Organize" button
2) Select "Folders And Search Options"
3) Select the "View" tab
4) Click the "Show Hidden Folders And Files" radio button.
To View Hidden Folders in Windows XP:
1) On the Tools menu in Windows Explorer, click Folder Options.
2)Click the View tab.
3) Under Hidden files and folders, click Show hidden files and folders.
