Power user TIP
Thread begun 5/24/2019 9:47 am by Steve | Last modified 5/24/2019 9:58 am by Ray Borduin | 542 views | 1 replies |
Steve
Power user TIP
There has been an odd issue where each new themed page will not allow content in the various editable fields unless there is a Cut N Paste, save and then Reopen.
The solution is to update your theme file to have a blank line present in each editable field. For instance:
<!doctype html>
<html>
<head>
<!-- TemplateBeginEditable name="MetaTags" -->
<!-- TemplateEndEditable -->
<!-- TemplateBeginEditable name="doctitle" -->
<!-- TemplateBeginEditable name="head" -->
</head>
<body>
<!-- TemplateBeginEditable name="MainContent" -->
</body>
</html>
Default which fails and causes added time to remedy the problem:
<!doctype html>
<html>
<head>
<!-- TemplateBeginEditable name="MetaTags" --><!-- TemplateEndEditable -->
<!-- TemplateBeginEditable name="doctitle" --><!-- TemplateEndEditable -->
<!-- TemplateBeginEditable name="head" --><!-- TemplateEndEditable -->
</head>
<body>
<!-- TemplateBeginEditable name="MainContent" --><!-- TemplateEndEditable -->
</body>
</html>
I take it to be a DW problem? But having a solution definitely saves time. Maybe update the behavior to add the added line by default?
I'll get that updated. Thanks for the suggestion.
