On file upload, if file exists and no new file is selected for upload, leave existing
Thread begun 5/22/2019 11:27 am by lr_leal239405 | Last modified 12/08/2020 10:03 am by Ray Borduin | 4047 views | 10 replies |
lr_leal239405
Another thing I'm trying to achieve is - I have the File Upload function working, but I don't want it to erase what's already there on the UPDATE page when there's no file selected. (I have 3 actually). I have tried the codes's below, but it always gets erased:
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_FILES["Image"]["name"] == "") {
if(isset($_POST["Update"]) || isset($_POST["Update_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "Image", "0", "", "true", $WA_UploadResult1_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult2");
if(!empty($_FILES)) {
WA_DFP_UploadFiles("WA_UploadResult2", "Image2", "0", "", "true", $WA_UploadResult2_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult3");
if(!empty($_FILES['Image3'])) {
WA_DFP_UploadFiles("WA_UploadResult3", "Image3", "0", "", "true", $WA_UploadResult3_Params);
You have your bindings set to update from the form. You should use the "Server File Name" binding from the file upload server behavior bindings.
instead of:
$UpdateQuery->bindColumn("Image", "s", "".((isset($_FILES["Image"]))?($_FILES["Image"]["name"]):"")  ."", "WA_BLANK");
it will be something like:
$UpdateQuery->bindColumn("Image", "s", "".($WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_1"]["serverFileName"])  ."", "WA_BLANK");
lr_leal239405
Yeah, that works now. Not sure what WA_DFP_UploadStatus does or what ["serverFileName"] vs. ["name"] is exactly, but it works ! Thank you.
lr_leal239405
We realized we can't delete on Update once there's a file there because it's updating from Server. Works great, but now......I would like to add an option to delete. Do I have to add a checkbox and write a function? I'm looking for simple approach.
I have this now
$UpdateQuery->bindColumn("prod_img", "s", "".($WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_1"]["serverFileName"]) ."", "WA_BLANK");
I would probably add a separate form with a hidden form element containing the file path and a hidden form element with the database record ID. Thenn use the Delete File Server Behavior and Update Record to clear out the old value based on the form button and hidden form element value.
lr_leal239405
Just to update this, a while back, what I did was added a checkbox that deletes the field data when selected.
I simply changed this on the Update function:
if (isset($_POST['delImg'])) {
$UpdateQuery->bindColumn("prod_img", "s", "".($WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_1"]["Name"]) ."", "WA_BLANK");
} else {
Not sure if it's good practice but it works fine for this purpose.
lr_leal239405
Hi. A while back I asked this question and it seemed to resolve. However it won't work on this new page:
On Update, code below still erases the photo that is already there. Is the code above correct? should it leave the picture if already existing one? Thanks for your help.
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../../tips/images/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_UploadFiles("WA_UploadResult1", "tip_photo", "0", "", "false", $WA_UploadResult1_Params);
$UpdateQuery->bindColumn("tip_photo", "s", "".($WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_1"]["serverFileName"]) ."", "WA_BLANK");
Yes... on this line:
the "0" means overwrite. To rename the new file with a number use:
WA_DFP_UploadFiles("WA_UploadResult1", "tip_photo", "2", "", "false", $WA_UploadResult1_Params);
lr_leal239405
It keeps deleting the existing file name form table column any time I press the "Update' button. I tried after changing to 2 per your instructions (also tried 1 and 3 btw). No matter what, it removes the file name from the table column.
Attached is the entire file. Thank you.
lr_leal239405
Ok, I found a workaround. Never mind for now. Thanks.
