/webassist/framework/ajax_wrapper.php error on checkout page all of the sudden on multiple sites...
Thread begun 5/22/2019 8:56 am by Justin@AdventDesign | Last modified 5/22/2019 10:52 am by Ray Borduin | 1598 views | 4 replies |
Justin@AdventDesign
I tried several threads but to no avail. This has popped up on two different sites (built in tandem mirroring each other closely) at the same time. They are at least three year old sites that haven't had significant work for several years. Made some changes two months ago, but nothing to do with the cart. Client just notified me this AM both sites now throw the following error when trying to 'continue' on the checkout page:
"Not Acceptable
An appropriate representation of the requested resource /webassist/framework/ajax_wrapper.php could not be found on this server.
Additionally, a 406 Not Acceptable error was encountered while trying to use an ErrorDocument to handle the request."
I've confirmed all the /framework/ pages are mirroring what I have locally. I've re-uploaded the ajax_wrapper.php in case there was some sort of a file corruption issue. I've tried to confirm file path though it looks like it pulls from the JS file that gets me a bit lost. It's odd because nothing in that folder has been changed.
Could some sort of server software upgrade throw a wrench in the ecart system from a few years ago? How else can I troubleshoot?
framework folder and checkout page attached.
Justin@AdventDesign
See PM for online replication...
Update the framework files to the latest version and this issue should be fixed. I think the two files that need to be updated are:
webassist/framework/javascript/ajax.js
and
I've attached the newest versions for you. Recent updates to the apache mod_security module make some servers block the ajax communication thinking it is malicious. The latest versions have been updated to get around the problem and pass security checks.
Justin@AdventDesign
That indeed did the trick, thanks Ray!
BTW - Any easy way to force a cache dump of those files? I had to go incognito to get it to pull the new files so any of their customers who recently tried to checkout will have a similar issue I'm guessing.
The php page won't be cached. You could manually update any references to the ajax.js file to add a parameter like: ajax.js?id=2 and that will cause it to be automatically refreshed.
Realistically this isn't a major concern. Unless the user was on your site today and hasn't closed his browser window the cache would be updated next visit to the site.
