userupdate.php deleting password if not updated
Thread begun 5/21/2019 11:50 am by Justin@AdventDesign | Last modified 5/22/2019 10:02 am by Ray Borduin | 1662 views | 5 replies |
Justin@AdventDesign
Created all the standard security assist pages with the wizard. In testing, I'm finding if I DO NOT enter password and confirm password on the update page, the Update Record behavior is wiping out the encrypted password entry in the database. If I do enter a password on the update, it appears to code it correctly. I haven't manipulated this page outside of the wizard. How do I troubleshoot?
Please attach the page. I need to see if you are using MySQL or MySQLi to give you the correct steps to fix this issue.
Justin@AdventDesign
I should have thought of that... attached.
It looks like you updated this page from MySQL to MySQLi and the password update line wasn't changed properly. On line 52 you have:
$UpdateQuery->bindColumn("UserPassword", "s", "".((($_POST["User_Update_group_2_Password"] != ""))?WA_HashEncryption($_POST["User_Update_group_2_Password"]):$row_SecurityAssisttblusers["UserPassword"])  ."", "WA_BLANK");
The part that refers to the old password is still in MySQL syntax and has to be updated to MySQLi, so it would be:
$UpdateQuery->bindColumn("UserPassword", "s", "".((($_POST["User_Update_group_2_Password"] != ""))?WA_HashEncryption($_POST["User_Update_group_2_Password"]):$SecurityAssisttblusers->getColumnVal("UserPassword"))  ."", "WA_BLANK");
That would fix it, but there is actually an easier way to do it with MySQLi. You could just use:
$UpdateQuery->bindColumn("UserPassword", "s", "".((($_POST["User_Update_group_2_Password"] != ""))?WA_HashEncryption($_POST["User_Update_group_2_Password"]):"")  ."", "WA_IGNORE");
The WA_IGNORE argument at the end tells it to simply not update the field if it was left blank. That way you don't have to set the value to the previous entry with the recordset at all.
Justin@AdventDesign
Hmm... I had thought for sure I did a completely clean and fresh install, as I'm doing a total rebuild of my backend system. I'll give that a whirl. Thanks.
It is possible you used a tutorial and the syntax was in mySQL not mySQLi. I can't be sure of how it got to this state, but the point is that the line is using the old methodology and has to be updated to work with mySQLi versions of the update page.
