incorrect INTEGER value:
Thread begun 5/16/2019 2:36 pm by randyrie405335 | Last modified 11/14/2019 8:37 pm by anonymous | 1927 views | 4 replies |
randyrie405335
When I submit my update form, I get this error: "incorrect INTEGER value: " What might be causing this and how do I fix it?
anonymous
Reply
This post has been deleted.
This means you are passing a blank value to a column that is set as an integer. If you provided a copy of the page then I could probably give more information.
Juan
I have the same Problem when I use any Get, Server, or Binding as filter
Any Idea?
<?php require_once('../Connections/ixtapa.php'); ?>
<?php require_once('../webassist/mysqli/queryobj.php'); ?>
if (true) {
$DeleteQuery = new WA_MySQLi_Query($ixtapa);
$DeleteQuery->Action = "delete";
$DeleteQuery->Table = "places_hotel";
$DeleteQuery->addFilter("id_place", "=", "i", "".($_GET['id_place']) ."");
$DeleteQuery->execute();
$DeleteGoTo = "index.php";
if (function_exists("rel2abs")) $DeleteGoTo = $DeleteGoTo?rel2abs($DeleteGoTo,dirname(__FILE__)):"";
$DeleteQuery->redirect($DeleteGoTo);
<!doctype html>
<html>
<head>
<meta charset="UTF-8">
</head>
<body>
</body>
Are you passing in an integer value in the url for id_place when you see the error? What url is this at?
