A script in file UNKNOWN has been running for a long time.
Thread begun 5/16/2019 7:07 am by vernon webb | Last modified 8/31/2022 6:20 pm by Ray Borduin | 1918 views | 4 replies |
vernon webb
Every since you edited the time_results.php file I have been getting "A script in file UNKNOWN has been running for a long time." message to which I say no to and it goes away, but it keeps coming back every time I do anything in the file and when I open it.
This is because of the hand coding I added closely matches the code the Server Behavior adds, but doesn't match perfectly. Dreamweaver tries to make sense of it and can hang for a while. I've updated the page so it won't happen anymore if you download the version I just uploaded.
vernon webb
Michael
Hi Ray,
I have been having issues "A script in file UNKNOWN has been running for a long time." although you didnt work on my application. I dont know exactly what is causing it but I am suspecting its from and update script.
It shows whenever I am opening a project that probably has that update script. Please can you share an sample of the update you made so I can use to resolve my case.
This issue causes me to loose a lot of precious work time.
Thank you
Mike
If you attach the page that has the issue then I can take a look and figure out the cause and suggest a fix.
