converting mysql to mysqli
Thread begun 5/15/2019 9:50 pm by Jamie | Last modified 5/20/2019 1:39 pm by Ray Borduin | 2148 views | 3 replies |
Jamie
am just trying to convert some old code to mysqli (attached txt files) and pretty sure that the repeat regions on lines 6 and 22 are causing the page not to work but unsure what I should be replacing them with
Cheers
Jamie
Yes. I think at this point you should probably just delete the old repeat region code and apply the MySQLi repeat region manually in its place.
So remove the first instance of the line:
<?php do { ?>
and then remove the lines:
<?php mysql_free_result($ProductOptions); //mysql_free_result($OptionGroups); ?>
              <?php } while ($row_OptionGroups mysql_fetch_assoc($OptionGroups));
mysql_data_seek($OptionGroups0);
$row_OptionGroups mysql_fetch_assoc($OptionGroups);?>
and select the code in-between and apply the mysqli repeat region using the OptionGroups recordset.
Then it looks like you also have a dynamic select list that wasn't updated to MySQLi. To fix that, delete this code:
<?php do { ?>
                  <option value="<?php echo $ProductOptions->getColumnVal('OptionID')?>"<?php if (!(strcmp($lastSel$ProductOptions->getColumnVal('OptionID')))) {echo "selected=\"selected\"";} ?>><?php echo $ProductOptions->getColumnVal('OptionName')?> <?php echo ($ProductOptions->getColumnVal('OptionIncrement')?" (+ £".(number_format($ProductOptions->getColumnVal('OptionPrice'),2)).")":""); ?></option>
} while ($row_ProductOptions mysql_fetch_assoc($ProductOptions));
$rows mysql_num_rows($ProductOptions);
  if(
$rows 0) {
mysql_data_seek($ProductOptions0);
$row_ProductOptions mysql_fetch_assoc($ProductOptions);
Then highlight the select list and add dynamic attributes from the properties window to make the select list dynamically populated from the ProductOptions recordset. Just choose any column for the option title and value.
Once it is back on the page, then delete the <option> tag added and put back in your custom one by copying and pasting the value from before:
I think that should fix the page.
Jamie
thanks Ray
its not quite working as its not showing the relevant options as per the PM. Have attached the page
I found a few issues with missing brackets and I think a bad IF statement, but I think they are fixed now. Please download the page and test to see if everything works now with other products.
