Fatal error: Cannot redeclare RemoveValue() (previously declared /home/rotaryribi/public_html/webassist/email/WA_Email php:616)
Thread begun 5/15/2019 4:23 am by Sweens | Last modified 5/17/2019 1:19 pm by Ray Borduin | 4882 views | 21 replies |
Sweens
Hi
I've mucked something up somewhere, as suddenly I'm getting
Fatal error: Cannot redeclare RemoveValue() (previously declared in /home/rotaryribi/public_html/webassist/email/WA_Email.php:616) in /home/rotaryribi/public_html/webassist/email/mailformatting_php.php on line 382
This is affecting EVERY update page.
I have a backup of mailformatting_php.php and have restored that, but no difference.
UPDATE; it's not the update page that's affected, it's the page to which it redirects; this has email facilities on it, which is where the problems seem to be.
This page uses pre-mysql_i universal email.
Cheers
Chris
Delete the line that references: mailformatting_php.php
That is leftover from the old version of email and is no longer used.
Sweens
Thanks Ray.
I've removed the line and the page opens without error - but after sending the email, I get:
Fatal error: Call to undefined function writeUEProgress() in /home/rotaryribi/public_html/adminsection/clubadmin/a-pages_Email.php on line 147 I've attached the page, if that helps.
Note, I haven't got round to updating this to the latest version yet.
Cheers
Chris
I was under the impression that the email code was updated. You will need the line you just deleted for the old version of the email. Here is an updated version you can put in your site to prevent conflicts. (attached)
Sweens
Hi Ray
Thanks so much - all OK gain now.
Cheers
Chris
Sweens
Hi Ray
Just discovered that if you are logged in, the error message returns; logged out and the page is fine.
If I remove the mailformatting_php.php include, the page displays fine but I the email won't work.(Fatal error: Call to undefined function writeUEProgress() in /home/rotaryribi/public_html/districts/page.php on line 79)
Chris
Here is an updated version of that file. If you still get errors, post the exact error here and I'll make another update.
Sweens
Hi Ray
Thanks - but:
Fatal error
: Cannot redeclare RemoveValue() (previously declared in /home/rotaryribi/public_html/webassist/email/mailformatting_php.php:364) in
on line
713
Cheers
Chris
Make sure the mailformatting_php include file is below the securityassist include and WA_email include if they are on the page as well.
Sweens
Hi Ray
The includes are:
<?php require_once("../webassist/email/mail_php.php"); ?>
<?php require_once("../webassist/email/mailformatting_php.php"); ?>
<?php require_once('../Connections/connRIBITro_i.php'); ?>
<?php require_once('../Connections/connSTATS_i.php'); ?>
<?php require_once('../webassist/mysqli/rsobj.php'); ?>
<?php require_once('../webassist/mysqli/queryobj.php'); ?>
<?php require_once("../webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once("../webassist/form_validations/wavt_validatedform_php.php"); ?>
I've tried moving it to be the last one, but no difference.
Cheers
Chris
